mounting a propane tank, who did it?
Bbasso
Expedition goofball
For my next van I plan on having on board propane for a few uses...
Has anyone mounted a propane tank in a E series and what was your method,,, pictures would be awesome.
Bbasso
Expedition goofball
145 views...
not one person has taken on this?
odd...
So what do you do to store/use propane on your E series?
mojave joe
I did mount a small horizontal tank under a 97 e350 a few years ago. It was a royal PITA! The hangers got bolted up to the frame first and it took some thinking to make it come together. The front required a piece of angle to span across from the frame and a body stiffener. I also had to do some cutting on the body to clear the valves and fill connections. Good luck!
TBS
On our last big trip I saw a really nice SMB that had a horizontal tank like the one you pictured on the drivers side frame with an access door on the lower rocker area of the body. It was a really nice set up, 110v plug was also behind the same access door. Much later down the road I'd like to do something like that.
In the mean time.....my current solution. It works. I've had it back there for about a year now, and was insanely cheaper that a horizontal tank.
Bbasso
Expedition goofball
I've seen those comments toward your method of mounting the tank... lol
I'm not afraid of comments but I do want it out of sight (as much as possible).
Thank you for adding some info.
Tdavis8695
