Mounting Alu-Box to Baja Rack
C-Fish
I'm going to pick up an Alu-Box ABS56 to mount to my Baja Rack.
I'm wondering what the consensus is for securing it permanently.
Conventional thought would be to drill holes and use u-bolts....not sure if this would weaken the botttom skin enough to cause premature failure(s).
Thoughts?
Kcdude
How about using a thicker strip of aluminum on the inside, drill through it and the secure with U bolts...that way you are distributing the load across the strip versus a nut/washer against the skin. Could even add some rubber grommets that mash/seal when you mount it.
C-Fish
Good idea. Thanks.
Petersmithinak
