DirtAddictLC80
Looking for some folks with experience to chime in on mounting options for a FWC Hawk on a 2004 Toyota Tundra. I've read that the standard mounting suggested for Four Wheel Campers may be problematic for extended off road travel.
For a 2004 Tundra, FWC says to mount eye bolts at 12 inches and 61 inches from the front of the truck bed. I checked the underside at these locations, and in both places it looks like there is a (relatively thin) metal brace the runs across the bed. Using the standard mounting procedure, I would drill through the bed and through these stock metal braces using the hardware I recently purchased (seen in the pic below). My plan is to use a round washer and nut on the top, and a square washer and nut on the bottom, locking in the eye bolt to the bed.
I'm concerned because the stock metal bracing running across the bed is not that thick. I'm wondering how this set up will hold over washboards and heavy articulation, considering what I've read. Is there a better way to mount the camper? Should I be using different hardware or turnbuckles? I would think that the turnbuckles should at least have springs in them to allow for a little flex, no? The turnbuckle, pictured, came with the camper. The camper was bought used so I am not sure if these are what FWC provides or if the previous owner bought these separately.
Thanks!
Eye Bolt Hardware for FWC
FWC Turnbuckle
Thanks!
FWC Turnbuckle
