Traveler18
MULE expedition outfitters Four Wheel Camper accessory bracket. This was used on a FWC with a jerry can mount, which is not included. Included is a custom aluminum plate to take up space on your jack bracket if you want to take your jacks off and keep the mount on. Also included are some bolts that I cut short to use with my wavian jerry can mount should you want to mount one. You have to cut the bolts off because these brackets are very close to your camper. Also included is a bolt that I used on the bottom. You have to drill down from your propane cabinet to mount this bolt. This mount worked great but I sold the camper. Willing to ship for the added cost.
