Coachgeo
So sat in the Ambulance box I purchased for my Expo Truck project today. Some brainstorming ensued. Here is what some clouds brought to my mind..... the door from box to cab will not be used in its present configuration. I might try moving it to passenger side. More on that later. So thought is... seal it up on inside then do below
. Put toilet in the space where that cab/box doorway was. Originally figured a pullout toilet in a cabinet somewhere.... but dedicating this particular space just for this seems to fit. Shower/bathing will NOT be traditional anyway so it is OK to be by electrical cabinet for this use. Again more on bathing later
. Murphy Bed / Toiletry door - Install a door in area marked in solid red in schematic below. Door to open like normal to reach toilet area. But.... standing up on one side of door a Muphy bed of some form. One idea is door will have to have hinges that can be unlatched and latched. Lowest hinges latched allows bed to be lowered. After the Z's are done... stand up bed then latch the typical door hinges for daily open close of toiletry door then Unlatch bottom hinges and whala... you're set for the day's use.
. Bed will be about 6" to 12" short so it will need small extension for feet or head. Would rather hang bed from roof after lowered with adjustable length straps. This will allow bed to be level no matter how unlevel the truck is.
What do ya'll think?
See red below. dashed red is bed lowered.
