Specs
Front Bumper to rear, listed are the salient upgrades, replacements, and repairs
Front of Truck:
ARB Winch Bumper
Warn winch
IPF Aux Lights (2)
IPF Headlight housings
Sylvania Silverstar H4-55w/60w Bulbs (stock wiring, no upgrade needed at 55/60w)
New OEM Grill painted Satin Black/Cast Iron Ceramic Duplicote
New Aftermarket Headlight Doors
CruiserCrap TEQ bottle opener on bumper
Driveline& Suspension:
TG Aftermarket Steering Stabilizer
AllPro Hysteer Arms
80 Series TRE's
Custom Rice Built TieRod and Drag link
Appropriate Pittman Arm
Coarse Spline FJ40 4.11's in front diff
First Gen Longfield cryo-treated Mini-truck Birfs
New Knuckle/wheel bearings OEM
Marlin Inner Seals
All bearings except for inner wheel bearings and carrier bearings on front replaced
HFS Barbell Shackles with 2.5” extension all 4 corners
Aussie Poly Bushings with grease channels all 4 corners
Greasable shackle bolts all 4 corners
Greasable spring hanger pins all 4 corners
Alcan 5” Lift leaf springs (they have simmered a bit to 4.5” but flexible
6 degree shims (perfect correction)
Custom Length Swaybar links with Energy Suspension bushings
New Bilsteins all around
New u-bolts up front
New u-bolts and SOR Extreme Ubolt skid plates in back
New Aussie Locker in back
New Yukon 4.11's R&P in back
All new seals and bearings in back OEM
E-brake accuator cables in back
FJ-55 pinion flange/yoke in rear (needed for fine spline gears)
Replaced U-Joints on rear driveshaft
Vehicle has extended axle breathers and brake lines
Faux Bead 15x8 Steel Rims in Black
Goodyear MTR's 35x12.5
Transmission is the stock 4spd
Transfercase is stock
Engine has been desmogged
JimC Idler pulley
JimC Carb
New hoses
New Cap/Rotor OEM
New Carb Insulator plate OEM
Fle-Pro I/E gasket
New Collector gasket OEM
New NGK v-Power Plugs
New fuel filter OEM
New Oil Filter OEM
New Plug wires OEM
New Thermostat and housing gaskets OEM
New belts OEM/Goodyear
New Inspection Cover gasket OEM
New Oil Pan gasket One Piece
New Valve Cover gasket OEM
K&Air Filter
New Motor Mounts
Carr-McMaster Silicone vacuum lines
Saginaw power steering conversion with large capacity cooler
New radiator
More Exterior:
CCOT 62 Style Charcoal Grey Mirrors
replaced bulbs and covers for corner lights
New Housings/Covers/Bulbs for tail lights
Sliders
Non-USA rear slider windows
Largest Defender Roof Rack available
8x Groucho/Rising Sun Roof rack feet
60 inch Hi-Lift jack (mounted to rear bumper)
Side vents painted to match grill/headlight doors
SROR Rear Bumper with tire carrier and ladder
Interior: (Overall very nice)
Dash is perfect minus one small tear where the gauge cluster cover meets dash
Aussie Inclinometer
CruiserCrap TEQ Shifter knob
All Gauges function
Non-USA grab handle (good condition pad/metal painted Cast Iron Color)
Tuffy Console w/ Pioneer Navigation plus Changer/CB.The Navigation is sweet. It folds in so that you can lock your tufty console.
Pioneer AVH-P5200BT
In-Dash DVD Multimedia AV Receiver with Built-in Bluetooth and 7''touchscreen Display
DVD VideoDivX, MP3/WMA/iTunes AAC playback
iPod Direct Control
SD Card Slot
Navigation AVIC-U220
Add-on Navigation System
Pioneer CD-SB10
Sirius Bus Interface for use with Pioneer "SAT Radio Ready" Headunits and AV Receivers
SiriusConnect™ Universal Vehicle Tuner Model#: SCC1
Replaced front speakers with nice Pioneer 6.5"
All seats are in great shape and have SOR Tuff Duck Covers
Carpet is an 8.5 of 10
Rear Cargo Carpet and padding is New
Ultimate Air Regulator/Hose/Mounted Rack with old Coke CO2 Tank (large capacity)
WagonGear Tailgate Storage Lid w/ tumbler locks.
