ZooJunkie
Over the weekend I replaced my outer cv boots and added more suspension travel to the front, and tonight I added more clearance to the rear.
First, replacing CV boots are a PITA. Each side took me about roughly 6 hours to do. The first side took the longest, as I wasn't quite sure which way was the best way, and so ended removing too much stuff off my truck!
Did a ball joint flip, that was easy, so far I haven't cranked up the torsion bars yet, and it doesn't ride that bad. I need to run down to PepBoys and pick up a shorter bump stop.
Speaking of PepBoys, I picked up these gems for $10 each, Coil Spring booster, which I used as my new top hat. That work nice! I immediately saw a nice change in my ride, not as bouncy and it's more stable at speed! $20! Woot. I was debating on buying these: http://www.independent4x.com/item.html?UCIDs=839915%7C1100654&PRID=1211881
Though probably not as high quality, they work! Plus I get to pocket $80 for some other part. :chowtime:
So on with some pics of my rear coil spring booster installation.
1st pic, comparison between OEM and PepBoys. Breather tube! This thing exits through our chassis cross member! Nice touch Isuzu.
Oh, I still have SS lines to install from Ind4x4. Darn.
