My turn for a trailer build!
Andy G
Figured I'd give it a shot. This is my first ever fabrication/welding sorta project.
This is gonna be towed behind our JK as well as my FJ62. Will use it for camping supplies, and when we transfer (I'm active duty Coast Guard), we'll be hauling personal stuff in it as well.
Outer frame is 2"x3" .120 wall steel. Cross members are 2" square .120. Tongue is 2" .188 wall. 3500# Dexter axle assembly.
Ordered everything...and waited. Things do NOT come quickly to Kodiak. :ylsmoke:
Finally...things started showing up.
Started laying pieces out, measuring, and cutting. This is the basic layout (4'x6') with the tongue in position, but not completely ready to go (see later pics).
Main frame welded up, mocked up with the tongue and axle assembly.
Horizontal parts welded - done! This is the underside. I braced in the 4 corners, and added a lot of extra tongue support as well. A little overkill is just fine with me...
Topside ready to go.
I'm VERY happy with things up to this point. Square was only off by 1/16th of an inch. This rookie is VERY happy with that. The plan WAS for a 4'x6' trailer, but some crappy cutting equipment at the base auto hobby shop changed that to a 46"x70" (outside dimension) trailer. No worries!
Up next...getting the leaf spring mounts in place and welded up. Then start working on the sides.
Curtis in Texas
Great start. Looks good and I wouldn't sweat the off size too much at this point. You won't miss the inches.
One thing is for sure, you're going to have to try hard to bend it!
That's for sure. :victory:
Curtis
ntsqd
Heretic Car Camper
If possible take a big hole saw and put a hole in the middle of those gussets. It won't hurt the gusset and it will make it harder for dirt, mud, & debris to build up on them.
PolarXJ
Looking good! I'd second the holes in the gusset bit. I've got some arms that support my rocker protection and I'm amazed at the amount of mud those hold.
Andy G
Roger that, good idea. I was thinking of trimming them back a bit but didn't want to loose any integrity. A hole in the middle should do just fine!!
msand1977
Off topic, but is the Mecca still in Kodiak?
highlandercj-7
NICE! Im happy to see someone actually build a frame instead of adding onto a piece of a stock one. That is more sturdy, faster, and looks 1k times better.
Houie
