POWER PACK DC25
The National Luna Power Pack DC25 blends the convenience of a portable battery system and the performance of a DC-DC battery charger with MPPT solar regulator. This combination results in a self-contained split-charge system that is at-home in the vehicle or in camp and can be used to power fridges, lights, pumps and other 12V appliances.
The Power Pack DC25 can be charged from a vehicle alternator, solar panels or external chargers making it versatile for a variety of applications.
Features:
- Built-in DC-DC Charger
- Built-in Battery Gauge
- 1x Solar input
- 2 x Dual USB QuickCharge ports
- 3 x DC Sockets standard (2 x Cigar, 1 x Hella)
- 2 x 50A Grey coupler plugs standard
- NL5 Intelligent Charger port (charger available separately)
- Fused Outputs
- Dimensions : 495mm x 258mm x 305mm (L x W x H)
- Max battery size : 325mm x 180mm x 280mm (L x W x H)
- Battery not included
- True 25A output current
- 6-stage intelligent charge algorithm
- 12V and 24V input
- Smart-alternator compatible
- 25A, 375W MPPT solar regulator
- Supports solar panels up to 42V
- Supports AGM, Gel, Wet, Calcium, Lithium Ion/LiFePO4 batteries
- Battery temperature compensation for safe charging
- Short-circuit protected
- Reverse-polarity protected
- Over-voltage protected
- Over-temperature protected
