2006 Chevy Express here,...and in wanting to add a battery bank that will PRIMARILY POWER THE 2 Cig Lighters (i.e., Aux Outlets) in the van for trickle charge while the van is not on,....I have been following the article below as a reference and have a very basic question about the installation of the battery with a continuous duty solenoid...
http://voices.yahoo.com/van-dwellers-adding-extra-batteries-van-dwelling-3685596.html?cat=7
perhaps he is leaving a step out, or I am not grasping the concept....
but I am at a loss as to how the Aux battery will be separate from the main battery while powering the Auxiliary Outlets through the Solenoid. The Aux outlets are always hot as we know... but.... I'm wondering how they will be powered from the Aux and leave the Main alone unless I do some rewiring I have not seen mentioned.
Should I assume that this continuous duty solenoid will simply do it for me? Will I need to add something to the fusebox (slot 29) that goes directly to the Aux Batteries? And if I do so,....would that not open up flow back to the main battery (which is what I wanted to separate while the car is off to begin with)?
Would I have to install a diode somewhere to cut off the flow back to the main while the car is off? All replies are appreciated!
