need help figuring what the heck this is!!!! long shot...
Motorvated
Nature Junkie
This was in the back of my truck when I bugth it. I have two of these brackets.
Than this thing..
nickw
Forget the brackets, killer 1980's boogie board:)
Edit:
Actually it looks like the two brackets you have are ment to stand vertically over the front bumper. If you could stand them up so the brackets (right side of pic) are on the ground while the large pieces stand vertically (looks like there used to be tubes between the large pieces holding them parallel). In this position the brackets (ones one the right with the two holes in top) may sit on your frame. I dont see how you could attach that front bumper to the vertical pieces though.
Look to see if you have any holes in your forward frame section-
The top two pics look like parts of a Warn brushguard/winch mount. There should be a winch tray that bolts between them and maybe brush bars that bolt on the outsides
Motorvated
Nature Junkie
hey man! thats my boogyboard from when i was like 10 haha..
So what about the bumper looking thing? What the crap is that
tacollie
Glamper
That looks like is is winch bumper missing the tray. My brothers look just like that, except he has the center part and his doesn't have custom mounts.
Clutch
<---Pass
What you have are the side peices, looks like you are missing the center tubing.
The other bumper looking thing, Looks like it is a PreRunner bumper of some sorts. The way you have it laying, the upper loop should lay flat.
Might be a Downey Off Road bumper. Or a Smittybilt.
Motorvated
Nature Junkie
your the man! It doe slook like the downey bumper..and idea how it mounts? I must be missing some brackets or something.
Clutch
<---Pass
No idea....It would seem if you flipped the bumper towrards you 90 degrees, it should mount like that. The lower hoop might hit the spare....hmm.. anyone else have some thoughts.
iStan814
