rcintx
Hey all,
I need some help getting my 1981 Suzuki TS100 running again. I recently moved back to my hometown, and pulled the bike out of my Dad's shop. I haven't ridden it in at least 8 or 9 years. It is a small dual sport, but would be perfect for toiling around on dirt roads around town.
Since the bike hadn't been started in a good while, I drained all fluids and replaced them. The carburetor was gummed up and stuck, so I tore it apart. A couple cans of carb cleaner later, all parts are clean and back in motion.
Put everything back together and got it to fire up after a couple of kicks. I love this bike, always, always started for me growing up.
Now here is the problem and where I need help. The bike WILL start and continue to run if you work the choke (on and off). If you turn the choke off, the bike runs at full RPM for a few seconds and then dies.
I am pretty sure there is a problem with the carburetor, but don't know what. I tried adjusting the air/fuel mix screw as well as the float height. Neither seem to make much of a difference.
Any advice? I really want to do a full restoration on this thing and put some miles on it. Thanks in advance!
