Need help with mounting my Spacekap Diablo Camper Conversion to F150
kiar
Hi everyone, I recently mounted my Spacekap Diablo to my 6.5' bed but the platform I made has the camper sitting a bit too high to have the typical mounting system that comes with Spacekap. I've resorted to using ratchet straps but I'm aware the factory tie-down points in the corners of the bed aren't the most structurally secure since the bed is aluminum so I'm thinking of DIYing a solution, let me know if this would be possible or if I'm just shooting myself in the foot:
I'm thinking of drilling two holes through my truck bed floor on either side near the cab near the factory tie-down points and mounting d-rings to the frame of my truck. The idea is to drop down the ratchet strap from the Spacekap mounting bracket down through the hole and attach to the d-ring on the frame. I've attached a photo of a d-ring shackle as an example of what amazon offers. Looks like I would probably need to attach longer lag bolts. Would this work?
Alloy
Those are flush mounted. How big of a hole do you plan on drilling in the frame?
Have you looked at
Eye bolts
Eye Nuts
Forged D rings
simple
Have you contacted spacekap for their mounting system? They have one for most of the new vehicles. There is a spacer that fits in the bed and vehicle specific stainless plates that fit under the bed rails for the clamps to compress down on so that it doesn't distort the bed rails.
kiar
yeah we know spacekap has their own mounting system but 1) it’s so overpriced and 2) the way i have setup my platform i also added insulation inside which isn’t possible with spacekap’s
kiar
abctrash
