Need info on any stove\sink combos
jamm
Seeking some help in finding a reasonably priced two burner LP stove\sink combo that can be mounted on a flat surface. Something similar to what is in RVs. I'm looking for a something about 16-18" deep by 30-36" long. I've searched RV places online but haven't found anything.
Any help is appreciated.
Sportsman Matt
Biggest thing is you won't find a "ready made" combo. You can try to find one in a used pop up camper, or just build one.
The question is are you going to be making this portable or permanent install?
Reason I ask is that my current camper setup is a 3 burner stovetop and 9"X12"x5"deep sink with a coldwater faucet built into the countertop. But my cooking is outside 99% of the time, so I use an old Coleman 2 Burner gas stove for cooking.
I've seen a couple setups that are interior and some exterior, and some portable. We really need a little more info to help.
One thing you can do is check out RV Surplus, they carry all sorts of RV appliances and hardware. Might be a spot to check out.
Good luck
jamm
I should have been more specific in my initial info request.
The question is are you going to be making this portable or permanent install? My plans are to mount this on a slideout drawer on my M101 trailer.
Reason I ask is that my current camper setup is a 3 burner stovetop and 9"X12"x5"deep sink with a coldwater faucet built into the countertop. If I could find one similar I wouldn't have a problem modifiying it to fit.But my cooking is outside 99% of the time, so I use an old Coleman 2 Burner gas stove for cooking.100% of the cooking will be outside, I'm trying to eliminate carrying the portable stove.
I see these units all the time in campers but cannot find any suppliers for them.
jamm
I am finding that most are manufactured across the pond, which you may already know, but I found these were manufactured by SMEV in Italy and Others Made by Dometic,Thetford,Cramer. http://www.ozvan.com.au/category27_2.htm
http://www.smartmarine.co.nz/plumbing-gas-gas-ovensstoves-c-40_1152.html Is this the direction your discussing? I will keep poking around and see if I can find something more if it is.
Yeap, that is similar to what I'm looking for.
However I'd like to find something not as pricey. Surely there is a US manufacturer that makes something comparable.
bucketosudz
Here you go JAMM, I am not sure it gets any cheaper...http://cgi.ebay.com/ebaymotors/ws/e...akeTrack=true&ssPageName=VIP:watchlink:top:en
This one is manufactured by SMEV the Italian company mentioned. "SMEV manufactures Italian-designed, residential-style RV cookers and sinks. It's market share exceeds 55% in Europe and 85% in Australia. Though the company just entered the US market, it already supplies important American clients such as Dutchman, Coachmen, and AIRSTREAM. The company has built its success by integrating design, high technology, and quality in unique products." this quoted from the AIRSTREAM Knowledge Sharing Forums. These stoves are now being distributed by a company called AeryCorp out of Goshen, Indiana. I found his post on the previous mentioned forum, the company is setup as a commercial vendor.
They have a couple of options... Hope this helps.
jamm
Thanks SUDZ -- That is exactly what I was looking for. :wings:
bucketosudz
Glad I could help. I can't offer much to the Portal Community by way of experience with vehicles and such, but I have pretty decent "GOOGLEFOO!!" That and being a "Stay-at-home Dad" allows me the time...occasionally! :victory:
YaRiteZ71
