I have 2 x Exped Mediums that I purchased from MooseJaw during a sale a few weeks ago. Now, I will admit, sizing is not 100% ideal because my sleeping platform is up higher and this location does reduce some width for the two Expeds to sit perfectly. This is how I roll when I have two people inside the Landy. I do not inflate them with the pump until I have them positioned side by side and then get the right fit and air pressure that way (takes about 2 minutes to set up and then it stays. If my platform was lower I think the Exped twin size would be perfect fit. But, I use my Expeds as singles for my TentCot, Solo Landy Use, and SideXSide as a mattress in my ARB Simpson RTT. I like the versatility of single or dual use and being able to split them up as needed and not be committed to a large mattress. The Solo Trip Single Exped is obviously an easy fit.
***I did not put the sheet/blankets I have over for reference purposes in these photos. FYI, the fit of the SideXSide Expeds with the slight overlap and/or seam in the middle is not noticeable or felt when the sheet/blanket is over the pads.
CONS of both set-ups: They both cover the easy access to my center seat NL Weekender 50 fridge/freezer; I can still access with no problem but it does have its downside for sure.
Someday in the future I may have a custom mattress built for the platform that has a flip open area for the fridge access! The Super Tramp find looks very similar to my ideal design; only I would go a tad thicker I think and never look back.
![IMG_6128.JPG IMG_6128.JPG](https://expeditionportal.com/forum/data/attachments/483/483014-cb28c2452b98325929559829b462fbfa.jpg)
