New Dodge!
toyrunner95
The phrase, "Thats ma boat." comes to mind when I bought this bohemith of a truck.
This story begins about 6 years ago when I was just out of boy scouts and hangin out with my friend Alex. We were looking for a trucks to go to college in and it was a toss up between a toyota 4runner and a dodge 2500. Well the mpg factor at that time played in, so I ended up with a 4runner. Alex however was off to Wyotech and bought the Dodge.
About two and a half years ago at Thanks giving, he was on his way over the i90 pass in Wa when a tree fell on the vehicle he was riding in. Total act of god, 70mph and a tree falls on his car, not infront of it, not in the road and he didnt see it, ON it. It killed him.
This summer I came to the conclusion that I cant afford to keep my toyota pickup and I was tired of beating on my subaru to go to side jobs. I needed a truck. I decided it was time to get the dodge I wanted. After talking to a few people I found out that Alex's Dodge wasnt in the wreck as I originally thought. I got in touch with his parents and they said it was for sale.
I sold my Toyota truck, and my 4runner and picked up the Dodge for 8k.
Its a 2001 Dodge ram 2500 SLT laramie with the Cummins 24v diesel with 187k on the odo. From what I hear I pretty much stole it. It Blue books at 10,500. It needs a new set of tires and some TLC but its compleatly tuned up and runs like a champ. The tale gate has a dent in it and there is a little rust around the edge of the fender wells from rock chips but everything else checks out fine.
I do have one problem. The ABS and BRAKE lights are constantly on and i cant figure out why? Any ideas?
Here are a few of my pics ma new boat.
attachment.php
attachment.php
attachment.php
redthies
Renaissance Redneck
I don't know how you are trying to post pics but nothing is showing... Congrats on the new truck, sorry about how you got it though.
toyrunner95
The pics show up fine on my end. Sometimes servers are blocking the pics. When im at work I cant see any of the pics either.
if you want to see it try this:
http://wow4x4.com/bulletin/showthread.php?p=8426#post8426
Its a local assocciation up here trying to keep public lands open.
The plans for this thing are mostly work but it will get modified into an expedition truck soon enough. I have to pay it off first.
chasespeed
IF you have brake light, and ABS light, you probably have a bad speed sensor....
Watch the speedo closely(and carefully), does it seem lazy? react a little funny?
The rear sensor is also your speedo-sensor...
There could also be a broken wire in the front sensors....
Those are the 2 most common problems, and, with both lights on, it leads me to believe that is the problem. I have the 01 S/M on my hard drive, and can help you out with other things if you need....
Oh, check out cumminsforum.com, there is a section for the 24v cummins era trucks....
Chase
toyrunner95
Well I installed my GPS today to check the speed on the speedo vs the gps. I know the GPS is 99% accurate. The speedo is off by about 5mph. Im guessing because of the tires. I have metric 34s on it, 315/75 r16. So I dont know what to think. Is there a way to test it?
Also I seem to have a starting issue. When its first starting either cold or after a few hours from its previous run, it takes like 5-10 seconds of cranking and 2 or 3 tries to get it started. Its like the fuel line isnt staying pressurized or something. Any ideas?
the 24v motors are notorious for havign lift pump problems. i have a friend who also has an 01 and he has been down this road before. i my self am nto a diesel guru but it does sound like the lift pump to me. this based on hearing my buddie complain about the same problems. hope this helps.
i talked to my buddy. he said that the lift pumpm would not supply enough fuel to the injection pump, thus ruining the injection pump. i had some info reversed. sorry about that. anyway, it sounds likek this may be your problem
19psi
The Devil Made Me
before you do anything else, upgrad your lift pump. get the airdog 100. a little research at cummins forum will tell you all you need to know.
toyrunner95
I need money before I can fix anything that doesnt cost more than about 5 bucks. So far i have fixed a few of the little things, just to bring it up to par. one of the interior lights was out. It needed a new battery J-hook, one was so rusted it looked like a spike. Im going to install my cb tomorrow maybe.
What does the lifter pump do? And how does it differ from the normal fuel pump?
redthies
Renaissance Redneck
Correct me if I'm wrong but I believe the lift pump feeds the injection pump with fuel from the tank. The injection pump then distributes fuel to the cylinders.
D
DEEZLPWR
Guest
i would go aftermarket and get a fuel pressure gauge, egt gauge minimum.
Also do the vent tube mod or you will lose oil on anything more than 22deg downslope.
http://mopar.mopar1973man.com/personal/2002/bombs/crankcase-vent/cranbkcase-vent.htm
i did the mod already and went down a 40 deg slope at red cone colorado and didnt lose a drop. i would still put a catch bottle on it to get the vapors. my oil pressure stayed where it was supposed to the whole time!
but do the lift pump asap as you dont want a dead $1200 injector pump.
been there done that. $3000 later full fuel system replacement, injector pump, lift pump, edge juice with monitor(well worth it as it saved my engine once already before i did the vent mod).
toyrunner95
Has anyone use the BD kit? I did some research online and I found only 3 bad reviews, but i'm pretty sure they werent the exact same kit I am looking at.
mbauerus1
