Regarding 275/70x18 33" tire fitting: I do know I'll have to mod the struts to increase the bump stops at a minimum.
Why the bumps stops? I don't think so necessarily. I've used my LLAMS tool to drop the vehicle as low as possible and the scrubbing it not too crazy but it is lots of contact against the fender liners. What I'm getting at is altering fender liners where needed vs changing bump stops which would start to reduce range of articulation.
(at maximum drop, the warning comes on and it wants to be raised but what's cool about the LLMS special red button is that it "locks" the system such that the vehicle won't lift up even though it thinks it needs to)
I've mainly tried this full drop with spacers which make the fender liner situation worse. No spacers should keep the tire tucked where there's more liner space left up top - maybe.
My bigger concern is at the 3 and 9 o'clock positions of the tire/fender gap. The rear 3 will get really tight at those spots and with the Kaymar, using oem mud flap as the gap filler, it's even less space than factory rear bumper without mud flaps. Kaymar did a really weird thing there that basically requires the bulky stupid oem flap. In fact it's not even a "flap" but too rigid to move at all. I'd rather have it gone and use replaceable thin flat flaps like on Defenders or my D1
Up front a 33" will get right into the ARB bumper which houses some things right in that area like washer fluid or something. The next to impossible spot would be where we've already removed frame steel at back of front wheels.
