Hey there, so I have been lurking for the past few weeks and decided that I needed to join. I live in Arizona and figure that I have some awesome destinations around me to go explore. So I might as well build a truck to do it! I have a 2wd 77 shortbed chevy. I have found a 4x4 frame and 1/2 ton axles here locally. So I have a few questions.
1) Has anybody on here made the swap from a 2wd to a four wheel drive?
2) I want to find a manual transmission for it, the guy that has the frame has a manual transmission, I just need to identify it. I at one point had a 79 4x4 that had what they call a 4-sd, but really it had a super low granny gear and three normal ones. Do those transmissions do well for exploring, minus the no overdrive for the highway cruising.
3) The reason I ask about these transmissions is obviously I will be lifting the truck up. With the lift comes bigger tires. If I leave the differential gearing stock and put 35's or 38" tires on it, will the granny gear somewhat compensate for the stock gearing when I need to move slowly? And what will the effect on cruising down the highway be? Will I get better gas mileage, but have no power?
4) I might have the oppurtunity to get a cabover camper that came out of a dodge dakota, for the right price..FREE. Has anyone on the forum put one of these midsize campers in a fullsize shortbed? Will it work? Is there enough space left over to make some storage spots?
I realize this is just the tip of the iceberg, but I wanted some answers before I jump in head first into this project. I am limited by budget, but I can slowly work away.
Thanks in advance for the help! You all seem like a great bunch of guys that have a hella lot more knowledge then me.
