Rbertalotto
Hello, new to the site.......
I'm going to build an very light, expedition "shell" for my 3.4 ton 4X4 Dodge Diesel pick-up with 6.5' short bed. This will be a "tailgate open" camper.
Basically just for covered sleeping, storage, and a place for "co-drivers" to sleep on the long haul trips......
I've had two other pick-up truck campers in my lifetime, but they are all too large and heavy for what I need now.
Attached are the drawings for the unit I will be building. Being a well versed boat builder for many years, I'm going to use much of that technology.
The exterior will be 3/8" Epoxy impregnated Wacky Wood with the interior being 1/8" white fypon. All casework will be Mahogany frames with Baltic Birch doors. Two drop down bunks will be hinged to both sides.
Spray in foam will be used in the void between interior and exterior sheathing.
Portable "Cassette" toilet and Propane Catalytic heater will handle the comfort areas. Cooking, cleaning, showers etc will be handled outside.
My biggest challenge will be the two front corners which will require fabricating a double curve. I was thinking about solid block of Styrofoam with fiberglass cover? The side and front curve will be easily accomplished with Wacky Wood.
I've calculated total weight of 700 pounds.
I'm looking for comments, suggestions etc before I start construction.
Thanks
Thanks
