New off road
VE2WHZ
Hi i planed to build this
i would like your comment
tire is 31-10.5-15 at
fram ia made with tubing 1''x 2'' -1/8
wall
start on ext
alum sheet
thermo foil (is insulat for bubble with aluminum is give +- r5)
1/4 plywood
srew on fram
fram is mad with 3/4 x 3/4 tubing
the fram on interior is apparent
is good for hang ant thing...
is good idea to made the fram ???
is possibvle to take pic ...
if is not understand
Pascal
sseaman
The Flexride would be fine especially if you want the trailer lower to the ground. But you can also get by with a standard leaf spring setup.
