justinbmcbride
Jeep Gladiator Rubicon 4x4: $87,333
Odometer: 28,000 miles
Exterior Color: Firecracker Red Clear–Coat Exterior PaintInterior Color: Black Interior Color
Interior: Rubicon Cloth Bucket Seats
Engine: 3.0L V6 Turbo Diesel Engine with Stop/Start
Transmission: 8–Spd Automatic 8HP75 Transmission
Window Sticker
STANDARD EQUIPMENT
Jeep Wave Membership (Retail Sales/50 States Only) Advanced Multistage Front AirbagsSupplemental Front Seat–Mounted Side Air Bags ParkView® Rear Back–Up Camera
Front Disconnecting Stabilizer Bar
4:1 Rock–Trac® Part–Time 4WD System Heavy–Duty Dana® 44 Wide Front Axle
Heavy–Duty Dana® 44 Wide Rear Axle
Tru–Lok® Rear Axle
Tru–Lok® Front Axle
Fuel Tank Skid–Plate Shield
Transfer Case Skid–Plate Shield
Front Bumper Skid–Plate
Terrain–Specific Off–Road Plus Mode
7– and 4–Pin Wiring Harness
Electronic Trailer Sway Control
Torx Tool–Kit
Push–Button Start
Location Specific Tire Pressure Monitoring Display
Front Door Passive Entry and Lock
Uconnect® 4C NAV with 8.4–Inch Touch Screen Display 4G LTE Wi–Fi Hot Spot with Trial Included
SiriusXM GuardianTM Connected Services w/1–Yr Trial SiriusXM® Travel Link with 5–Year Subscription SiriusXM® Traffic Plus with 5–Year Subscription SiriusXM® with 6–Month Radio Sub Call 800–643–2112 Apple CarPlay®
Google Android AutoTM
Alpine® Premium Audio System
Integrated Voice Command
Reconfigurable Cluster 7.0–Inch Color Display
Air Conditioning with Automatic Temperature Control Full Function Media Hub with 2–USB Plus Aux Port Premium–Wrapped Steering Wheel Steering–Wheel
Mounted Audio Controls
Tilt / Telescope Steering–Column
2–Way Manual Lumbar Adjustable Driver Seat
OPTIONAL EQUIPMENT
Firecracker Red Clear–Coat Exterior PaintCustomer Preferred Package 26R
Trailer–Tow Package
Class IV Receiver Hitch
Trailer–Hitch Zoom
Cold Weather Group
Heated Front Seats
Heated Steering Wheel Remote–Start System
Leather–Wrapped Steering Wheel
Premium LED Lighting Group
LED Tail Lamps
LED Front Fog Lamps
LED Premium Reflector Headlamps
Jeep® Active Safety Group
ParkSense® Rear Park–Assist System
Blind–Spot and Cross–Path Detection
Adaptive Cruise Control/Fwd Collision Warning
Automatic High–Beam Headlamp–Control
Auxiliary Switch Group
4 Programmable Auxiliary Switches
Freedom Panel Storage Bag Delete
Selec–Speed® Control
Transmission Skid–Plate
3.73 Axle Ratio
Body–Color Freedom Top® 3–Piece Hard Top
Forward–Facing TrailCam
EXTERIOR MODS
Front BumperAEV EX Front Bumper
AEV Skid Plate
AEV Winch Mount
AEV Light Bar Mount
AEV Camera Relocation Kit
Baja Designs LP6 x2
Baja Designs 20” S8 with Factory Amber Lens
Baja Designs Squadron with Factory Amber
2024 High Airflow Grille
Winch Setup
Warn Zeon 10-S
Factor55 Fairlead
Factor55 E-Flatlink
Lift
Teraflex 3.5” Alpine RT3 Short Arm Extended-Travel
Teraflex Outback 3.5” Spring Front
Teraflex Outback 3.5” Spring Rear
Falcon Nexus EF 2.2 Fast Adjust Steering Stabilizer
Falcon SP2 3.3 Fast Adjust Piggyback Shocks
Metalcloak Rear Track Bar
Wheels
Nomad Split Spoke 17” Wheel x5
Modular Rash Ring Kit x5
Air Deflator Valve x5
Tires
Falken RT/01 37x12.5 R17 x5
Jeep Xtreme Recon Fender Extensions x2 Fronts
Engine Bay
AEV Ecodiesel Snorkel w/Prefilter
813 Electronics mount
Banks Derringer Tuner
Banks Pedal Monster
Around The Cab
Ditch Light Brackets
Ditch Lights: Baja Designs Squadron Sports
TrailRax TRMR Rack
Angled Maxtrax Mount
2 Pairs Maxtrax Xtreme
Rockslide Engineering Step Slider
Rockslide Engineering Skid Plates
Camper & Truck Bed
Tune M1 (Installed Feb 2025)
Blackout Package
Pre-wired for Solar
Pre-wired for Starlink mini with mount
Maxxfan 7500K with remote
Kammock Awning
Kammock Outpost Hammock Stand
Wolfbox Rear Camera/Dashcam
Bedrug
Hest mattress & Bedding
King-size bed extension
INTERIOR MODS
Front SeatsBulletpoint Rubigrid
Peak Design Phone Mount
CMM A-Pillar Mounts x2
Epic Kraken Tire Inflation System
ARB Twin Air Compressor
ARB Bluetooth Pressure Control Module
Desert Does It Seat Jackers
Epic Crow Molle Overhead Rack
Tazer Mini
Yaesu FTM-500 with MARS Mod for GMRS frequencies
Sound Deadening
Soundskin Global Sound Mattes
Armorlite Rubber Flooring
Lizardskin Sound Deadening Spray
Hothead Headliners
Rear Seats
Blue Ridge Overland Gear Attic
Vector Offroad Contour Rail
Goose Gear Back Wall Plate
Auxiliary Battery
3x Dakota Lithium135ah batteries
813 Under Seat Storage Bin
Redarc BCDC 1250d
Also Included
Goose Gear 60% Seat Delete
Redarc Manager 30
Redarc 2000w Inverter
Redarc Rogue w/Redvision
Back on the market after a loss in the family in April. I’ve tried to make this work as a commuter and family andventuremobile with my 1-year old daughter, but it was built to roam and not spent all day in the garage. I’m not looking for trades and no part-outs. Just did the full 30k maintenance on it, including front diff, t-case, and rear diff. Everything runs great, it just isn’t getting the use it deserves.
