New products on website
Martyn
I added a couple of interesting products to the web site this evening.
The first is a Fast Disconnect Shower, a really well made product $76.50:
The second is a bracket we had made for a 5 lb propane tank $69.95:
Both of these units are on our accessories page http://www.adventuretrailers.com/accessories.html
Shower looks great but im not entirly clear on what it is. Is this simply quick disconnect system and switch for your existing how water set up? or is this a complete hot water set as well as the cool disconect? In other words whats on the inside of the truck?
Mike
overlander
That shower looks to be the best solution yet of all the deck type showers I've seen! When I get to my onboard shower, I'm going with that one.
I too would like to see the displayed parts contents, and the back plumbing side of the fixture, to visualize the connections. I'm sure it's just a hot and cold line feed in though.
On the bracket, time to get busy and whip up a 10lb bottle bracket! I've googled to death, and there are none on the internet that I can find.
Martyn,
That is exactly what I have been searching for. The Holy Grail so to speak.
Simple, clean, dust and waterproof.
I'll be placing an order shortly.
Nice 10lb can holder too. Looks similar to the SS Powertank brackets.
ntsqd
Heretic Car Camper
I like the shower assembly. How long is the hose and is it possible to replace it with a fixed spigot?
bmonday
Martyn, can you post the dimensions of the tank bracket? I am toying with the idea of mounting a tank in the spot between my can holders, where my PowerTank is in this pic:
Oh, and does it support a lock?
Martyn
The shower unit consists of the mixer valve, and the hose.
The water system and pump is extra. We have everything you need for that set up. It's the same set up that we use in the Overland Teardrop Trailer.
I'll get more pictures next week, the back of the fitting is brass with pipe fittings for hot and cold water. When you disconnect the hose the waterlines automatically shut off.
The hose is 5ft long, you could take it apart and make a longer one.
The 5 lb tank is 8" in diameter, so it's slightly larger than the bracket used to hold the PowerTank. We know we tried to fit a propane cylinder in a Powertank bracket, their bracket is too small.
Sophia Lopez
