New to vans and need advice on what to buy
indecisivebrad
I'm in a quandary and need help from some veterans of this world. I'm looking for a 15 passenger 1 ton van or box truck to convert into a camper and am getting stuck narrowing it down. It'll spend most of its life on the highway being a home on wheels so I can't sacrifice fuel mileage or reliability too much. I figure about 20% of it's life will be spent hauling cargo and a handful of times a year it'll be pulling a trailer so it needs to be pretty tough. That's about as specific as I can get though. I know the future plans are based on travel and adventure so I can safely assume it'll see time parked on the beach and also in muddy fields. With that in mind should I go 4x4 or 2wd dually or would a base 2wd setup work with a locker and good all terrain tires? I'm trying to avoid a situation where my big heavy camper ends up buried to the axle, but I don't want to take on unnecessary expense and weight considering it's mostly a highway cruiser.
Also before anyone links me to those amazing conversions, I'm going with a cheap old van (or box truck) as a starting point.
Keep reading here and find yourself a 5.4 or v10 Ford van to build out. I would go 2wd and convert it if you decide you need it. Ujoint is probably the easiest way to do this. If you're going for a cheap old van as a starting point, you probably aren't going to find a 4WD van. Good luck.
I'm not even committed to a make at this point. I have pet peeves with Ford, Chevy and Dodge. That basically makes me an open to anything sort of shopper :********:
My only suggestion re: box vans is make sure you can have free passage between cargo area and cab. I didn't have that on my first build and it made for a very clunky feel when camping. So, that pretty much rules out all the wonderful flip cabs like Isuzu and etc. they ride like **** on the hwy anyway so that's two strikes.
I love my sprinter even though it's a bit of a labor of love, but she returns 25mpg in comfort and style at 75mph so that's a BIG plus for me.
And, as far as getting stuck goes, I can get anything stuck, so I'm trying instead to rock a 2wd van, horrible off road, understand its limitations and always carry appropriate recovery gear. You can always get unstuck, maybe you can't get to that special spot, but it's a van after all, so make accommodations and do without 4x4 if possible. It basically just means more time wasted getting unstuck, or putting on chains etc. but you save a bunch of money on the hardware initially, or in the case of sprinter, you can't have 4x4 at all because Mercedes are jerks. If skiing or snow use was a big concern for me I would place more value on 4wd but I gave that's stuff up when I started paragliding so I pretty much stay where snow isn't these days.
If you're going to tow anything then imho you should have the V10 or diesel. Better to have excess power then not enough.
If MPG are a concern diesel powered without a doubt.
Of course these are my opinions but based on first hand experience.
Great advice everyone. I really need all these first hand accounts. They help alot.
So far I'm leaning more towards a regular 2wd and bringing along some sort of sand recovery device for getting out of trouble. Not really possible to use a winch on a palm tree down here in florida. I will mount a winch too for when I venture back up north to see family. That should cover me in most situations I hope.
Watching "Alaska off-road warriors" this spring I learned two things about wheeling. One was that those folding land anchor things really work well for winching, and the other was the traction mats for under tires are a must! Again, not helpful for trips to the ski lodge but for those oops moments on the beach could make for an easy extraction without begging dudes for help.
I had been down on winches for years because for me here in the Nw a winch mounted on the front of a stuck vehicle is usually going to either get you farther into a stuck place, or pull you toward a tree and not into the road where you want to be or even worse, not be within reach of a tree that will help. The land anchor could change that especially in soft ground which is where we usually get stuck of course. So, for self extraction I feel a rear mounted winch makes more sense, however it's not as pretty of logistically easy to accomplish.
5mouse
