NIB Cobra 18 WX ST II
Spankin' new, latest model, never installed/unwrapped. Includes CB unit, all documentation/warrantee cards, wiring, mounting brackets, mic, hardware, etc.
-40 CB Channels
-Dual Watch: Simultaneously Monitor 2 CB Channels
-10 NOAA Weather Channels
For Taco guys/gals (95-04 gen.)- if you have an aftermarket radio in your rig, and a pocket underneath where the OEM used to be, all you'll need is a 90* coax piece and a heat gun to move the heater plactic about 1/4" to make this fit perfectly in that space giving a really clean in-dash install.
$65 + postage.
adrenaline503
I am thinking about getting one of these. Do you think it would be possible to change the LEDs to red? I look forward to seeing how it goes for you.
If your ambitious with electronics I bet it can be done, but if I were to use it, I'd leave it just as it is. There's a green LED channel indicator, a green one for dual watch indicator, a green one for scan indicator, red one for sound tracker noise reduction, green for RX, red for TX, yellow for WX, and green/yellow/red for SWR. It seems like a lot of work for little gain to switch all the LED colors around.
adrenaline503
Yea, I am an electronics tech, so if I can get in there without damage then it should be pretty easy. I just hate a multicolored dash and am trying to switch over all the aux stuff to red.
iStan814
