Non-plastic water storage options
Xtreme XJ
What are the thoughts on aluminium WWII 5 Gal. cans ?
Every old timer in the local 4WD clubs had one on their JEEP & one or two on their trailers...
I can see where extended storage might be an issue, but what about cycling fresh H2o in ?
Kgorman
I use dromedary bags from MSR. Work great and are easy to store when empty.
That said, using corney kegs is a fantastic idea. You can safely and easily pressurize for shower, cleaning, or even fire extinguishing. The downside is they don't tie down easily, maybe it's best to strap them down on their side and or build a containment cage.
Happy Joe
Apprentice Geezer
I used French military surplus 10 liter wine cans for years, they fit well in a jerry can holder over the rear fender wells of old Jeeps;
Blitz used to make lined 5 gallon jerry cans for potable water but they are a rare bird today.
I have also dealt with rubber water bladders they work but leave a taste.
I find nothing wrong with Sceptre water carries in either 10 or 20 liter styles (I use both).
Enjoy!
Kgorman
I just adapted a Cornelius keg for water storage. For a quick test, I pressurized it to about 15PSI and it works great. I would expect this will be great for washing stuff, spraying off bikes/kids/whatever, and drinking water.
I am going to pair this up with my ARB air compressor for camp use. My plan is to use the air compressor setting for max pressure so I don't need a regulator on the keg itself. I am shopping for fittings to make it useful around camp (on/off valve, sprayer head, fittings for charging it).
I'll post up pics when I get it working (or not working). Thanks for the idea all!
lrover109
How about 5gal cornie cans -the old school stainless soda kegs- you should be able to pick up at a craft brewing store and you get added benefit that with a pressure source you can have running water in your camp
Streaky
If you have any space inside the truck then make a full sized mock-up from cardboard to ensure a good fit. Once you're happy you can then get it fabricated in either aluminium or stainless steel and have it covered with automotive carpet.
This stainless tank has slosh baffles inside, has three cleaning ports and a filler cap...fabricated by a local guy close to where I live.
Petersmithinak
