Non power antenna for Gen 3 montero
offthepath
After hitting a deer the mount for the antenna motor broke on my Gen 3. I'd rather just put a standard antenna in. Has anyone done this? Which part did you use?
Thanks
nwoods
I used a short rubber stubbie antennna for mine. Feeding the antenna wire through the front quarterpanel/firewall was not very fun but otherwise easy project
coffeegoat
I just looked around in Amazon for one with a big bendy spring. It works fine but it's already rusting so I wouldn't recommend it. It appears to be a standard hole and plug. Don't forget to pull the relay so you don't have to hear the click every time.
SANelson
