Norcold MRFT40 Used Testing
krinderhagen
Norcold 110/ 12volt Model MRF40 refrigerator freezer cooler
It does not get cold the 12 volt DC side works as good as the 110 ac side there is 17.8 volts going to compressor condenser, I am not sure what the problem is
:Wow1:
I am interested in repair or selling it It is located in Hemet CA 92545 make offer
Testing of Unit
The first test is the ohms test of the condenser
My meter read all zeros
The next test is the power supply voltage test
My meter read 17.7 ac volts
The next test is the Compressor Amp Draw
Which I got first reading of 1.68 which is in reason however it soon dropped to 1.28 then remained steady
For some reason when I left it alone to write this post it started getting cold I am going to get a thermometer to check temp with specs
Using a laser thermometer it held at 19 degrees
After letting it run for an hour I tested the volts and amps again I got 15.8 volts at the condenser and 1.64 amps
Alexk
