Northstar TC650 Fantastici fan pre wire
dizzyspots
SO...I pulled the old vent out and replaced it with a Fantastic Fan...the TC650 is pre-wired for the fan. The ceiling wires (black/white) are cold. I pulled the distribution box..all fuses and breakers are good. Any suggestion where I might look...they do come out of the ceiling and go down the the pop up sleeve behind the frig to the fuse block but cant tell if they make it to the block or not???
Leaving the afternoon and would like to get it working...would appreciate any guidance
Cheers
brian90744
American Trekker
wiring location
I look at mine and the black(pos) & white (neg) wires all terminate on the left side of the rear of the refrig compartment. may look for loose wires here.? just FYI=brian
dizzyspots
Brian...my compartment looks the same but reversed...my bundle is on the right side of the refrig compt...several white/black all terminated in wire nuts...none loose?? Ill try to give Billy at Northstar a ring...thanks for the help
dizzyspots
Ok Brian heres the pics from my frig compartmentrefrig right side  single black.jpgrefrig left side pair to fan.jpg
The single black wire on the right side had a very old piece of masking tape on it, but couldnt make out what it said..maybe fa_?
Is it as simple as running a pair of wires from left side to the other side and tap into the single black wire and into a white (ground) bundle??
sprint
I ran into the same issue when installing a fantastic fan in my '93 Texson (Northstar). I just decided to run wiring over to the light 6" away and tie into that power. It is easy to feed the wiring through the styrofoam insulation.
dizzyspots
SUCCESS...we have fan! so simple take that solo black wire on the right side ..add it to the bundle of other black wires on the right side....bingo FAN!
Thanks for all the input.....scrubbed and detailed the outside after the Mount Graham trip...looks great for 12 years old!!!
