Seabass
Idiot
Ok guys, I know there's more than a couple of these old trucks in this section. I'm as proud of mine as can be, and it's my nicest truck. In fact, if I needed to travel far it's the truck I'd be taking. That being said the brakes suck. They are particularly weak since I stepped up to 35" tires. I'm just curious to see what some of you have done in regard to brakes and brake upgrades. I'm open to aftermarket calipers, rotors, pads, I'd even consider a disc brake conversion for the rear axel (if there is such a thing). The old truck is really heavy. It holds 100 gallons of fuel, has a heavy winch and winch bumper out front, a heavy steel bumper out back, custom side steps, massive skid plating underneath to protect the fuel tanks, and loads of tools, camping, and recovery gear. It's got a lot to slow down. Then when I hook my camper to it I'm less than happy. I'm not over gross, I'm fairly confident. If I am it's not much. I think I've got something wrong.....booster or something like that. At any rate I'm ready to do a total brake upgrade. It stops, but im really bearing down on the pedal. I don't like it. Since I have two of these trucks I can see a difference. My work truck is basically identical, just with a gas engine and no topper. But, it has a crap load of tools and gear I use on the farm. I'm quite confident it weighs close to my powerstroke truck. But, it has smaller tires (285's). I do think the larger tires hurt the powerstroke truck. I don't remember questioning the brakes before the tires. Anyway, I can always count on you guys to deliver some sound advice. Any would be appreciated.
