OFFGRID 2001 Ford F550 Flatbed Camper Boondocking rig FS/FT!!!
OverlandKyle
Yes, this rig was posted here just a few months ago....
I’m selling this truck because plans have unfortunately CHANGED….My loss is your gain! I bought this truck about two months ago off Expedition Portal with dreams of living in this and traveling full-time in this poor man's Earthroamer of sorts. It’s been an amazing rig and has served me well in the short time I’ve had it but several serious and unexpected life events (unexpected family obligations, job loss, and personal hardships) has completely upended everything and now I need to find a more traditional living arrangement and something to commute in.
2001 FORD F-550 Dually WITH CUSTOM FLATBED AND CAMPER
BRAND NEW FORD REMAN ENGINE
BUILT FOR BOONDOCKING AND CAMPING OFF-GRID
Please read below as this truck and camper have had SIGNIFICANT modifications.
The previous owners (Driven to Adventures) had this truck featured on Tiny Home Tours
Mentioned in video but not included: Baja Design Lights as they’ve been replaced with a 35” light bar mounted on bumper
Titled as an RV. Clean SD title in hand. Currently lived in and located outside of Philadelphia, PA
TRUCK
2001 Ford F550, 4x4, MANUAL ZF6 transmission with Granny Low
Ford 7.3 Reman engine with less than 7k miles (and only 198k miles on the chassis). Miles will go up slightly
245/70/19.5 (33’s) Michelin Tires with good tread
New KC Turbo and pedestal
New glow plugs with engine
New water pump with engine
Air ride system
New DP Tuner installed with 60hp Codes for Towing and Hi-Idle RPM - 1400 - for Warmup, Boost A/C output, Running a Winch, Jump Starting (also stock and kill switch positions)
Upgraded RiffRaff Diesel air filter
MaxTow Pillar gauges for EGT, boost, fuel pressure, and water coolant temp
Custom Iron Bull bumper
Upgraded radio with Bluetooth and backup camera
Custom kill switch
Cab has Noico soundproofing installed
Safe behind seats for valuables
TRUCK BED
Custom built storage, steel framed with PVC panels and heavy duty stainless steel hinges and aluminum trim
12 foot truck flatbed modified to fit 41” tires (like MPT 81’s) if desired (room for 41” spare tire in the storage boxes as well)
Hidden pass thru from camper to truck
ARB Twin compressor
See video of storage build here: https://youtu.be/17HEZCxZU9I
Camper
Major systems all gutted and redone
Propane completely removed
Espar diesel hydronic heater for air and hot water with 4 new vents in the cabin plus 1 into the basement to keep holding tanks warm in extreme cold. All vents can be controlled separately. Hot water is INSTANT.
Separate 5 gallon diesel tank for Espar system with gauge in cabin
High altitude kit installed on Espar
Espar Easy Start controller + thermostat
900 Watts of solar (Five 180 watt Grape Solar panels wired in parallel)
780 amp hr battery bank (Six 120 amp hr Victron AGM batteries)
Midnite solar classic 150 charge controller
Xantrex 2000 watt inverter/charger (with remote display) - controls convection microwave, rooftop a/c, kitchen outlets
Victron 300 watt inverter - powers all other electrical outlets and TV, saving power by not using the larger inverter
Airhead composting toilet with urine plumbed to black tank
3 stage water filtration system
40 gallon fresh water
32 gallon grey water
28 gallon black water (used for urine from composting toilet)
Mofi 4500 cellular embedded router
Poynting 5-in-1 MIMO (LTE + WIFI + GPS) antenna on air actuated lifting mount powered by ViAir compressor ( currently using ATT but can be swapped with the SIM card of your choice)
Reolink security camera with night vision
Vitrofrigo 7 cu **** MARINE fridge/freezer (compressor fridge with no ammonia)
Updated kitchen with 2 huge pull-out pantry’s
Convection microwave
Portable Induction cooktop
Rooftop A/C which can be started off inverter
Custom 7” queen foam mattress
Huge clothes storage in bed area
Upgraded MaxxFan Deluxe with remote
TV with built in DVD player (replaced)
Upgraded door lock with keyless entry option
All LED lighting
100% aluminum and composite construction!
Only wood is the table and 2 pull-out pantry slides
Built by Livin Lite BEFORE being sold to Thor
Two bike rack on rear ladder
Truck is currently mounted with removable Torklift fast guns. Jacks have been mounted on the camper but can be stored under the chassis if so desired
Things that have been added/done during my 2 month ownership:
$1500 worth of work to repair a leaking shifter boot, replace the yoke on the axle and driveshafts, new U joints, flush and a oil change, all done 200 miles ago. Clutch was checked and still has a lot of life left
2 Brand New Northstar/X2 Group 65 deep cycle batteries for truck ($700)
New shocks and Steering Stabilizer
Assorted New cables and plugs ( 50 amps, 30 amps, reverse polarity plugs)
New Headlights and bulbs
17,500 lb Smittybilt winch
LED Light bar on front
32 inch Insignia Smart TV with FireTV
New induction stove
New Oxygenics showerhead
Ravenwolf Marine Anti-condensation mat for underneath bed
Samsung TabA tablet to run solar monitoring and other entertainment options
Video Doorbell mounted on rear of camper
BLINK XT video security system
Outdoor bottle opener because we all need one :0
Bad:
There is some rust around the bottom of the doors and on the rear cab corners.
Typical expedition scratches and a few dents on truck and camper body
Driver seat has a rip and passenger seat is a different color ( seat covers will take care of this)
WIFI antenna currently does not go up and down ( was like this when I bought it, most likely a loose connection somewhere, will still go up and down manually if you get on the roof and raise it. It works exactly the same up or down so I never bothered to look into it)
NEW ASKING PRICE: $45,000 OBO or trade for a 4x4 van or smaller truck
Not many pictures of the interior as the youtube video does a better job of showing the interior but can supply upon request.
OverlandKyle
New Price, $55,000
I need to sell quickly so I can get an apartment and a commuter car to meet my new and unexpected obligations.
rawtoxic
Bump... This is a great deal and Kyle is a great seller to work with. Almost worked for us and Kyle was great to deal with! I would encourage everyone to take a deep look at this unit and the all the great upgrades. I'm surprised it's lasted this long!
OverlandKyle
Thanks Rawtoxic,
Still for sale and needs to go ASAP as I will most likely be moving in two weeks or so and cannot take the rig with me
replied to all PMs
I ran a build sheet request and the truck does have a limited slip differential!
coast runner
