Offroad 6'x10' Trailer - Reduced $3500
ExpoMike
SxS/Quad Hauling or Squaredrop Trailer
Located in San Diego, CA
$3500
I was going to build a Squaredrop camper on this chassis but going a different direction due to health issues. I bought this from another ExPo member.
This is one of two prototypes build for the US Air Force Special Ops to haul SxS
Deck is 72” wide by 120” long (6’x10’)
Capacity ~ 2400 lbs.
Multiple 5K pound tie points and 4) 7K pound air lift points
Ark Jack Extreme 750X tongue jack
Timbren Axleless Independent suspension
2" Ball mount (includes pintle hitch ring)
High ground clearance (20") and side angle clearance
2 storage boxes that can hold fuel cans, supplies, etc. Removable
Rear storage basket
All new LED lighting and wiring
Titled and licensed
No load ramps
Squaredrop Trailer frame idea I was going to build
mog
Kodiak Buckaroo
A few questions (and a bump)
Is the Timbren suspension original to the trailer, or an upgrade to what the Air Force was using?
What is the lug nut pattern, 6x??
Tire size?
Tire track width?
Is there a spare wheel/tire?
Are the brakes electrical, and is there a battery for them?
What is the hitch high above the ground when the trailer is level?
Thanks
ExpoMike
Tire size?
Tire track width?
Thanks
Timbrem suspension is the original install when built. Nothing changed.
Lug 6x5.5"
265/70-17 (32")
Track ~ 68"
Yes there is a matching spare.
No brakes but spindles will accept them.
Lowest setting 25" currently. Can be raised to 27" or 29"
flipstick
