jaydon44
So i bought one of these things about 6 years ago when i started building my camper so that i could have it handy to design the trailer
I rigged it up and confirmed no leaks before this winter and upon a couple times using and testing it recently the LPP alarm on my safe-t-alert would sound every time after about 3-5 minutes of use...vented with window and roof vent
I had it installed over the summer not using it, i did NOT HAVE IT COVERED or protected from dust, other then assuming i had built an air tight camper i assumed it would be fine until i got around to fabricating some type of cover
Before i had it installed it was stored in the box inside the plastic bag except for the hand full of times i took it out to take measurements
I understand that these platinum mesh elements are very sensitive to dust/damage rendering them less efficient if exposed or damaged.....but already!?!?!
I live in Canada and bought this heater from the US because we can’t get them up here and I “assumed” when the heating element wore out or “clogged up” i could just order a new one and replace it, but the manufacturer won’t allow that for safety concerns regarding randos screwing with their propane products so now my only option is to drive down to the boarder and send this thing back to the manufacture for “repair” and wait for it to get sent back and pay a standard screen replacement/SH/labour fee of 159$ US
Ive been in contact with their info@camco guy and he has been awesome
I’m lucky enough to work for a fire dept and was able to borrow and use a gas sniffer; vented or unvented the LPP never went above 7ppm but it was ALWAYS detected when the heater was on
Unvented of course the oxygen went down to like 19 percent after a 5-10 minutes
And unvented the CO went up to ranges of 1-3ppm after 5-10 minutes which is fair to camco’s claim of “99% efficient burning heater”
These times are all after i warmed up the heater as per instructions with a large vent and on full “high” mode for 10 minutes to effectively warm up the platinum mesh
And the alarm only goes off when the heater is turned on and running so that tells me that there for sure no supply leak unless by chance there is some freak problem with the thermocoupler valve which I wouldn’t have a clue how to diagnose
If any propane pro’s or people experienced with damaged camco wave elements in the past or ANYONE who’s knows more then me can chyme in i’d be very thankful
Can’t seem to find anyone with similar experiences on the net or forums....only reviews of how freaking awesome the heaters are....hence why I bought one
Thanks!
Thanks!
