**ON PAUSE** 2019 Ford Transit Adventure Van - Twin Turbo LOADED Build
AKS
We're pausing trying to actively sell our van for remainder of 2023 but will consider solid offers over $108,000 for immediate purchase. 42,800 miles. Thanks for looking!
If you’re looking for a rugged yet comfortable camper van to take far off the beaten path this one might be for you. Ford 250 Twin Turbo EcoBoost 148” wheelbase, medium roof. The interior floor to ceiling height is 68”. Super clean, no smoking, no pets. Take a look at the photos and list of features and contact for questions etc is ashlieksolomon.com.
This van is fun to spend time in, and fun to drive. The EcoBoost Twin Turbo 3.5L GTDI V6 engine gives it plenty of get up and go. This model boasts a best-in-class gas torque rating of 400 lb.-ft. It features twin turbochargers that spool up more quickly than a conventional single turbo. The instantaneous low-end torque and HP you get with this engine are the result of direct injection, which delivers a precise amount of fuel to optimize efficiency and power. It easily punches onto freeways and past semis. We have appreciated the improved handling and steering of rear wheel drive over front wheel drive. We recently got 17.2 mpg on a 440-mile trip from southern Oregon to Tacoma, WA by following the speed limit and usually we get about 15-16 with a mix of city/off-road/highway. The Medium Roof keeps weight lower, gets us deeper into the forest, and gives it a sporty look. The 148” Wheel Base allows easier maneuvering and parking in parking spaces when you’re at the grocery store stocking up for your next adventure, exploring lunch spots in the city or negotiating switchbacks. The Hellwig rear Sway Bar keeps you planted more solidly on windy highways. We chose to carry MaxTrax vs having 4WD installed and it’s worked great for us in spots of deep sand and mud. We recently had Ford proactively install new brakes rotors. We’ve been diligent about her care and can provide all servicing records and system manuals. Everything is in working order. There are a few minor digs but otherwise no body issues. When loaded with fuel, water, inflatable SUPs, supplies, humans, our personal gear it is still nearly 1,000lbs under the GWVR (CAT receipt available).
This van was built for improved capability for off-the-beaten-path adventures. The upsized 17" MTM USA Heavy Duty wheels (Lifetime structural warranty), beefy Cooper Discovery AT/3 tires (Life of tire maintenance - 30,000+ miles of tread remaining), Foe’s Fabrication Transit Off Road 2” Lift, Bilstein B6 struts, Fox 2.0 Performance Series shocks will get you confidently into remote locations to camp in solitude. Exploring places to camp in the forest is no problem with the high-end Cyclops Adventure Long Range Optimus LED Aux Roof mounted lights. Store your MaxTrax inside in dedicated storage compartment.
Vehicle2019 Ford Transit Twin Turbo V6 Eco Boost
Color Magnetic Metallic
3.5L GTDI V6 – 310 HP & 400 lb/ft torque
42,800 miles
Medium Roof
148 WB
3.31 Limited Slip axle X3L
9,000lb GVWR
Front & Side Airbags
Power Steering
Leather seats
Cruise Control
AM/FM Radio/CD Player/Sync
6-Speed Automatic w/ Manual Shift mode
Rear Wheel Drive
Heavy Duty Trailer Tow Package
Trailer Brake Controller
4 Wheel Disc Brakes w/ ABS
4" Rear View camera with back up assist
Full Size Spare Tire & Wheel (stored under body)
Heavy Duty Alternator
25 Gallon fuel tank
New brakes/rotors (880 miles)
Power heated side mirrors
Ford AdvanceTrac® w/ RSC - Roll Stability Control
SOS Post Crash Alert System
Cruise Control
TPMS
Running Board
Scopema Swivel Passenger Seat
Still under 5 year/60,000 mile powertrain warranty
Still under 5 year/60,000 mile Roadside Assistance
Suspension/Off-Road Upgrades​
Bilstein B6 Struts
Fox 2.0 Performance Series Shocks
Rear Sway Bar
Cooper Discovery A/T 3 Tires – LT245/70R/17
17" MTM USA Heavy Duty Rims
Cyclops Long Range Optimus LED Aux Roof mounted lights
Transit Off Road 2" Suspension Lift
Fiamma F45s Awning
2 MaxxAir Deluxe Ceiling Fans
Smittybilt Defender Roof Rack
Insulation & Sound Dampening​
Wool Insulation - Walls R10, Ceiling R5/R7
Strawfoot Handmade custom Magnetic Privacy/Insulating Screens
Hardwood Floors
Water/Plumbing/Kitchen​
28-gallon Fresh Water Tank
RecPro 4-chamber Automatic Water Pump
ShurFlo Accumulator
5-gallon gray water tank or drain through floor
Waterdrop Direct Water Filtration System
K&H 2 Burner Propane Gas Glass/Cast Iron Cooktop
20lb Propane Tank w/ two-stage regulator
Large Farmhouse sink w/ Extendable Spray Faucet – cold water
Dometic CFX35 high efficiency Electric fridge on sliders
Magnetic Knife Holder
Large/deep kitchen drawer storage
Custom tile backsplash
Epoxy Butcher Block countertops
EccoTemp Luxé EL5 Tankless Water Heater Shower (garage)
Pull out dinette table
2 bench seats w/ washable cushion covers
3 large dresser drawers
Kidde Carbon Monoxide/Smoke Detector
Power​
Goal Zero Yeti 1400 Lithium Ion Power Station w/ Inverter
Two 100 Watt Renogy Solar Panels
Victron Energy SmartSolar 75V/15A MPPT Solar Charge Controller
Blue Sea ST Blade Fuse Box
Four 110V outlets/Six USB ports/Two USB-C ports
Furnace​
Propex HS2000 Propane 6500 BTU
Toilet​
Nature's Head Composting Toilet w/ 12V fan
Bed​
Custom Mattress with deluxe Upholstery 68”x74”
2" Natural Latex/3" Memory Foam
Sleep north to south
Slides up to a couch
Reading lights w/ USB ports
Bedside shelves for water/phone/etc.
Overhead cabinets
Bug Screens​
Rolef custom bug screens – Complete Deluxe package includes sliding door,
rear doors, fan shades, windshield shade and front window screens.
dhuss
