Onboard shower install question...
CaliCruiser
I am planning on starting my install tomorrow and looking for some tips and tricks on these systems. My first question is what kind of hose should I use on the 'hot' side of the exchanger? Would the white rv/marine hose pictured work on that side as well? As far as mounting the exchanger, I was thinking of putting it inline after the the heater core to obtain a bit of control but would it limit flow? How about switches for the pump, Should I mount it under the hood or run it into the cab? This is all going into my 60 series Toyota Landcruiser. . .
Thanks,
Dylan
Here is a shot of the materias I have now
The pump
The exchanger
LandCruiserPhil
Your pick up hose will work fine. Mount pump low if possible because flow will be loss if you need to drop your pick up down in a creek etc. Not sure about the pump you are using but there are limitations on water lift. Switch should be mounted where you hook up your hoses at IMO. Unless your exchanger is super efficient (most are not)use the flow of water to control temp unless you are limited by water supply.
If its not a secret I would be interested on what you using for heat transfer inside the exchanger.
CaliCruiser
Cool guys that is what I am after. Regarding the pump, it is rated at 2.8 meters of vertical lift, to self prime. Here is a shot of of the inside,when we design/built I basically did what another guy did on Pirate 4x4.
Do you think the heater hose, would make the water smelly or 'rubbery' for lack of a better word? I was thinking about using the nylon reinforced hose like desertdude did on his rig, any trouble with heat on that stuff?
Thanks,
Dylan
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
Here's a link that might be helpful: Hot water install
Also the shower head you have pictured doesn't seem to have an on-off button. I found that to be a pretty handy addition. I got a hand held shower head for $10 at Lowe's that works great.
HTH,
Ed
BogusBlake
2006 Expedition Trophy Champion
I guess I should have elaborated- I meant use the automotive heater hose for the engine side of the plumbing- where the engine coolant flows to and from the heat exchanger. That dishwasher hose will probably work great for the clean water side of the system.
CaliCruiser
Cool guys! I should have some progress pictures up soon with some hard numbers of temperature increase.
Dylan
LandCruiserPhil
I used heater hose on everything and after 6 years no funny smell.
Thanks,
Dylan
CaliCruiser
CaliCruiser said:
Based on this picture, I want to run the cold water through the ends of the xchanger through the small tubes correct, and have the hot coolant come in throught the top ports and surround the small tubes? This was my plan but while I was working outside today, my neighbors and buddies that stopped by said I should have the hot coolant run through the small tubes. This doesn't seem like it would produce enough surface area to transfer heat. Now I am puzzled! :eek:
Lets here what the ExPo has to say.
Thanks guys,
Dylan
burl40
Supporting Sponsor
he broI think the small lines run hot coolent and the large lines fresh water thats how the heat exchanger principal works....Check out deckers hot shower that exchanger looks alot like his......I am also doing an onboard heat exchanger similar idea as yours cant wait to see how yors turns out...Scotty
CaliCruiser
Thanks Scott, that is a nice setup, just a bit pricey. I'm going to do do some testing later today if I get some time.
Dylan
jacob_lashell
