ONE OF A KIND MOTOCYCLE/ OFF GRID TRAILER. FULL CUSTOM INTECH FLYER EXPLORER. Super light (Approx 2100 lbs) $20,000 LAS VEGAS, NV
GS606
Intech Flyer Explorer turned Into a Custom Motorcycle Hauler-Camper with Hot Shower, 28 gallons of Fresh water, and Bike Binderz Tie Downs and More!
This is a one-of-a-kind custom camper which started its life as an Intech Explorer. It has an insulated pop out for sleeping (full size bed), huge open cargo area for hauling motorcycles, bicycles or anything you want to bring with, additional drop down storage bins, an external kitchen with a two-burner gas stove and Dometic top load fridge, and large pantry storage.
We purchased this trailer from the original owner around 3 years ago. They never camped in it and only used it a handful of times to help with a move. The mattress was still in the factory plastic.
We’re a family of mechanics and fabricators so we went through and replaced/ fixed/ upgraded everything, even parts that might need replacement in the next few years so the trailer was pretty much brand new when we started to use it. We ever changed all the door handles and locks so one key opens everything instead of needing the 5+ original keys from Intech!
From there the entire electrical system was massively updated with a smart winter-heated lithium ion battery, DC to DC charger for 50 amp charging from the tow vehicle, 310 watts of solar, a digital controller with a touchscreen display to manage everything in the trailer and tons of lights inside and outside.
We then added a 28 gallon fresh water system including a DC water heater and external shower port for hot showers and washing dishes. This was a complete game changer for us to be able to be off grid for over a week and have daily hot showers.
The interior was set up with a flip up dinette, tons of cargo rails for securing anything, and two sets for motorcycle tie downs and two wheel chocks. These allow you to load two motorcycles in a few minutes without any tiedown straps and without compressing your front forks.
This is without doubt the nicest most set up, full featured Intech Flyer that we have seen anywhere. We have invested well over $15,000 in upgrades alone to make this one of the most amazing motorcycle trailers and bug-out campers anywhere.
It has always been stored inside since we purchased it.
Add Ons:
Electrical
  • Kisea DMT1250 50-amp DC to DC charger and MPPT solar controller
  • 2 Victron Energy MPPT 75/15 Solar controllers
  • 100 amp hour heated Lithium Ion battery (Relion RB100-LT)
  • 310 watts of solar
  • Victron Energy Smart Shunt
  • 2 Power Mon Smart Shunts
  • Outside light over kitchen area with external on/ off and 3 dimmer settings
  • Firefly Integrations G12 Control panel to control
  • Cabin lights with dimmer control
  • Mood lights (red) with dimmer control
  • Under Chassis lights with full color control
  • Awning light with dimmer control
  • Water pump
  • Water Heater
  • Fridge
  • USB outlet
  • 12-volt Socket
  • Water tank level sensors
  • Battery voltage
  • Interior and exterior temperatures
Water System
  • 25 gallon fresh water tank with easy drain valve
  • Whale 3-gallon 12 volt DC water heater
  • External shower port (Bulfinch) with hose
  • Whale plug and play water pump with filter
Storage and Living
  • Two Bike Binderz Adventure bike moto kit with rails mounting into frame of the trailer
  • E-track on the front wall of the trailer with removeable motorcycle wheel chocks
  • Custom flip up interior dinette
  • Luxe Liner insulation for tent
  • Chuck stop for fridge
  • Rear ladder for roof access which works on side or rear
  • OVS Nomadic 270 Awning with huge coverage
  • Tons of L track all over the inside of the trailer secured to the frame of the trailer
  • Custom Front cargo net for storage
  • Custom swing down overhead storage above the dinette
  • Custom insulated window black out cover
Replaced Parts
  • Ark Extreme Offroad swivel 350 lbs trailer jack
  • Roof painted with 4 coats of reflective white RV roof paint/ sealer
  • All door latches and locks replaced
  • AC unit seal replaced
  • All door seals replaced
  • Exterior rubber trim replaced
$20,000 USD
Located in Las Vegas
donaldsonmp3
