Our Skamper Redo
Willymutt
We bought a Skamper last summer for $250. It is the 080s model. We had a 1979 Fiber Kraft that we had redone some and really enjoyed. the problem was that with a toddler, it was just too small. So an upgrade was needed.
The camper was cheap because it had been neglected and the guy just wanted it gone. I knew the roof leaked because the roof was so heavy the lift wouldn't work. No biggie I thought, I can seal it and reinsulate.
Well, I started working on it and got to the point and figured it would be easiest to just pull the roof off. Of course, when I did that we started get lots of rain. What a pain in the butt. Then, I got a new job and we began to plan a move 7 hrs away. So much for getting the camper done. I pieced it back together and put it in a buddies lean too for the winter.
Fast forward to this spring, we finally get it hauled to our new home and I begin my plan to fix it. After digging into the roof more, I found that it was too far gone and decided to redo it. I almost threw in the towel with frustration but after reading SLO's rebuild, I got refreshed again.
Here you can see some of the rot.
A little of what the roof looked like with the insulation removed. No structure at all in there.
Off came the old roof and a new one started. I used 1/2" plywood for the frame. Then got some 26ga galvanized sheetmetal for the roof.
Here is the new roof on. It isn't perfect but I was using hand shears and a hammer to make the bends.
In hindsight, I should have done something better for the roof support but I was trying to keep it light.
I will insulate it after I know the roof doesn't leak anymore.
Of course, the door was rotten too. I built a new one out of a steel frame and some 24ga paintlock. I still need to paint it. Not sure the window will be reinstalled or not.
That is where we stand as of tonight. We have a trip the next 2 weekends for family reunions. The wife is painting the interior to lighten it up some. Jacks will be the next big thing to get done.
Cvonruex
