OUTBACK 4X4 EXPEDITION VEHICLE
KONA BOB
Manufacturer(s): Mitsubishi/Fuso Canter 4X4
Wheelbase: 134"
Engine(s): 3.0L DOHC 4-cyl Turbocharged Diesel
Transmission(s): 6-spd Duonic Automatic
Axle ratio: 5.714:1
Grossvehicle weight rating: 14050 lb
Unloaded vehicle weight: 10500 lb
Sleeping capacity weight rating: lb
Fuel Capacity: Std 33/Opt 85
Cargo carrying capacity: 3550 lb
Chassis warranty: 60 mo/175000 mi
COACH
Ext dimensions (lxwxh): 22'x6'10"x11'4"
Int. height: 6'5"
Ext. wall material: Fiberglass
Primary insulation: Polystyrene Foam
Underbelly material: Vinyl
Std. floor covering(s): Vinyl
Std. window covering(s): Miniblinds/Pleated Shades
Stove : 3 burners
Oven: Opt
Microwave: Opt|Opt microwave convection
Refrigerator: Std Dometic 8/Opt Nova Cool 12V 8
Power source(s):
Bath: Lavatory|Shower/Tub
Generator: Opt Onan 2.5
Inverter: Opt 2,000
Converter rating: 45
Furnace: Std (1) 30,000/Diesel-fired furnace & hot water
A/C: Opt (1) 11,000 & 9,000 BTU
Solar-power system: Opt
Satellite TV system: Opt
LP gas capacity: 10 gal
Freshwater capacity: 50 gal
Gray-water capacity: 30 gal
Waste-water capacity: 38 gal
Water-heater capacity: Std 6/Opt Hydronic gal
Beds: Queen/Dinette
Slideout room(s): Std Bedroom|Dinette|Full Wall|Kitchen|Rear/Couch
IN ADDITION TO STANDARD FEATURES I HAVE ADDED THIS LIST
2014 Mitsubishi EXPEDITION RV, This is a go anywhere expedition RV. I just completed a year long trip covering all of the Canadian provinces, Alaska and much of the US with no problems. Built in Oregon the vehicle features
Heating System- Espar Hydronic Furnace 5 D-WS
- Comfort Hot tank with 1.5KW (5,000 btu) electric heating element!
- 25,000 btu dual Fan unit, ducted!
- Engine Heat Exchanger 30,000 btu!
- Double Wall Heat Exchanger for tankless domestic hot water, 1gal/min,50ºF ?T!
- Espar Altimeter!
- Espar Error Code reader!
Electrical System
- 400Ah Lithium Iron Phosphate (LiFePo4) battery with 5.2 KWh of energy!
- Victron BMV 600 Battery Monitor!
- Under/Over Voltage Battery protection, measured at individual battery cells!
- Blue Sea latching solenoid as Battery Master Switch!
- Magnum MS Series, 3000 Watt Pure Sine Wave Inverter!
- Magnum ME-ARC Remote Control!
- Battery to Inverter cables as 4/0!
- TriStar TS-MPPT-45 Solar Battery Charger!
- Solar Panels 48 volt with PPT to 12 VDC
THE ENTIRE UNDERFLOOR IS DIAMOND PLATE, NOT THE STANDARD VINYL AND I AM INCLUDING A COMPLETE TOO SET ANS HONDA GENERATOR
Price: $150,000 negotiable
ANOTHER VIEW AND PHOTOS
http://www.hemmings.com/classifieds/carsforsale/mitsubishi/unspecified/1703849.html
pugslyyy
Good looking rig!
How does rear access work with the 2 spares like that?
GLWS!
Haf-E
Looks like the two spares are able to be tilted outward enough to each side to allow the door to open - simpler than a typical swing out solution - I like it.
Trail Monkey
Adventurer, Overland Certified OC0014
current photos
this is a very nice rig. and sharing the travel photos is always welcome here!
but for the purposes of sale it may be prudent to share some current photos focused on the trucks condition. and showing the rear door area deployed etc..
LandCruiserPhil
Where does the warranty stand in time and mileage? How many miles are on the rig now? How does the rig perform on the road faced with hilly terrain?
java
Just curious is this parked in Sultan with a for sale sign? Looks like a great rig.
iStan814
