Clark White
No good deed goes unpunished right? Well I picked up a half frozen guy on the side of the road today and when I went to pull away I caught something underneath. Didn't think much of it, but when I was almost home, the engine started knocking, still didn't think too much of it, no lights were on, I was only a few blocks from home, so I kept going. Check engine light came on with code P0115 and the engine died. At this point I was only a block from my house, so I started it up (almost didn't start) and parked it. By this time the knocking was very loud, but still no warning lights other then the check engine light, temp gage was normal. Just as I pulled into my driveway the temp gage jumped up and pegged out. This is when I noticed I had no heat. Turns out I had ripped off the lower radiator hose. At this point I was pissed. The gage read normal, I had no water temp light, and I hadn't noticed the actual temp on the scan gage, so I drove for probably 5 minutes with it over heating. Scan gage red 285deg F when I went back and looked :yikes:. Refilled the coolant, but the knocking is still very much there. I will change the oil tomorrow, but what is likely causing that knocking? I fear it is permanent damage, but I'm hoping not? Never had a vehicle over heat before, so I don't know just how bad this probably is.
Thanks!
Clark White
Thanks!
Clark White
