Overkill SO.5.10 — 2nd Owner | Early Steel Frame Unit | SUPER RARE POP-UP | Fully Optioned Build
This is an Overkill SO.5.10 and I’m the second owner. It’s one of the early units built with a steel frame, which is a big deal—this was when Overkill was truly taking the time to build these trailers the right way. The craftsmanship and materials on this unit are exceptional, and in my opinion, these early steel-frame builds are far superior to the later aluminum-frame versions.
This trailer was way ahead of its time in design and innovation. The layout is extremely efficient and the interior honestly feels twice the size once you’re inside.
I went through the entire unit and confirmed everything is working as it should, with one small exception: the interior pop-top lights aren’t currently triggering, and the new owner will likely need to track down why the SPOD isn’t activating the circuit.
This trailer was ordered new in 2021 with an original build price of over $48K (including registration/transfer/titling fees).
Base + Core Build
Exterior Storage + Utility
Cooking / Heat / Water
Electrical / Solar / Power
Windows
Awning
If you’re looking for an Overkill that was built during the “no corners cut” era, this is it. Clean, innovative, and extremely capable.
$30K Firm
Located in Denver, CO
feel free to dm or text me if you are interested 303-484-1550
Additional pictures upon request.
Original Order / Build Sheet (MSRP: $48,183)
Base + Core Build
- Overkill SO.5.10 Base Model — $28,900
- Pop-Top Roof — $4,600
- Early steel-frame build
- Front tube platform for exterior storage — $460
- Exterior storage box (batteries + storage bins) — $725
- Exterior storage box (fridge/propane/storage) — $825
- Swing-away spare tire rack — $745
- Spare tire (standard) — $395
- Partner Steel Cook Partner 22” 2-burner stove — $425
- Propex HS2211 propane cabin heater — $1,225
- Camp Chef on-demand hot water heater — $575
- (1) 20lb propane cylinders + regulators (hardline pre-installed) — $375
- Large 26G water tank on board
- Huge Snomaster dual zone 96L slide out fridge/freezer
- Accessory flood + spotlights on rack — $420
- HardKorr 200W Flex Array — $1,249
- Rotopax 4-gallon fuel container — $100
- Rotopax 4-gallon water container — $100
- Rotopax mount + locks — $175
Windows
- Tern Overland window in entry door — $425
- Tern Overland window(s) at front 45° slope — $350/ea
Awning
- Alu-Cab 270 awning — $1,650
- Custom vinyl wrap (color of choice) — $1,250
$30K Firm
