Overland XJ & Adventure Trailer - Autohome - Hannibal - Detour
jrfII
98 Up Country XJ 150K miles very nice condition mechanically & body.
Trailer is home built aluminum box. See reply below for specs on the XJ.
SW PA $11,000 will consider 300 miles if purchaser is willing to cover fuel for XJ & chase car.
If you are genuine and want details to consider purchase, pm me please. Let's not waste each others time please.
jrfII
Some specs for the Jeep
Specs:
'98 XJ Limited
Moss Green with Spice Leather Interior
4.0L, AW4, NP242
HP30 w/3.55s w/rock guard
Chrysler 8.25"w/3.55s w/rock guard
Rear Disc Brakes
UpCountry Suspension Pkg
Mopar T-case and Fuel tank skids
2" Hitch and Front Tow Hooks
Infinity 6 speaker sound system
New triple core radiator
LeBaron hood louvres painted & professionally installed
Interior:
Wet Okole water proof seat covers (leather was in bad shape)
All Carpet removed and steam cleaned and reinstalled
Pioneer Headunit with USB/Aux inputs
Husky Liners front,rear,cargo
5.25" MTX Replacement speakers all around
Exterior:
Front -
RC 3" Coils w/1.75" spacers
RC Lower Control Arms - Fixed
RC Adj Trac-Bar
RC Sway Bar Disconnects
Extended front brake lines
OME SD-40 Steering Stabilizer
Monroe Sensatrac YJ Shocks w/Homebrew BPEs
2" Lower RE Bump Stops
Daystar Upper Extended Length Bump Stops
New Moog ZJ V8 Tie Rod, Drag Link and Ends
New Unit Bearings
New Brute Force Ujoints
Rear -
ProComp Springs
Monroe Sensatrac MJ rear shocks
Extended rear brake hose
Performance -
K&N Drop-In Filter
APN Header
Carsound/Magnaflow Cat
Flowmaster 40 Series
2.5" welded pipe
Silverstar headlights and fog bulbs
Hella 500s on brush guard
Tires/Wheels -
16" Jeep Ultrastar Wheels
Falken Rocky Mountain 265/75/16 (like new)
4.5" RC Coils
1" Daystar Shackles
Chrome Grille and Headlight surrounds from a 00-01 Limited (like new in box)
DirtBound Offroad H/T SYE
Detours Tailbone Spare Carrier
Rola Roof Rack
Hannibal Awning (African made)
Body -
One minor spot of SURFACE RUST ON ROOF DRIP EDGE!
The body has NO RUST - NONE!
Original North Carolina Jeep - no rust on Unibody
Top edge of rear gate has the paint wore off
This is one of the cleanest Cherokees you will ever see! I am only considering selling it to buy or trade for a nice Wrangler. 150k on the clock, uses no oil I installed a new oil pump at 135k as pressure was getting low. Could use a front timing cover seal and the header has a small crack (typical) that can be welded. New PSE steering gear.
03rubicon
What is the suspension, you have two different versions. I'd also put some more info on the trailer. It looks nice and has some nice parts (Rubi wheels) tell people about them to justify the price
jrfII
No, if I sell it will be both trailer and XJ I am not willing to sell the trailer alone. Yes it is the XJ in the Jeep forum.
UncleBilly
Boy I thought I was anal 😜 That is one clean rig! I want a LandCruiser but man, this almost makes me change my mind! Just a great set-up for travel, good luck selling, hope the new owner takes care of it and enjoys it...
TonKa33
Boy I thought I was anal  That is one clean rig! I want a LandCruiser but man, this almost makes me change my mind! Just a great set-up for travel, good luck selling, hope the new owner takes care of it and enjoys it...
Agreed, this is an inspiring jeep trailer combo. I have a 1998 Range Rover, but not thinking it's great for this type of project.
JSKepler
