Pair of Baja Designs XL-80R round lights, white lenses, plus various harnesses and splitters
KG4NEL
I have a pair of Baja Designs XL80R auxiliary driving lights, the round version of their most powerful light they make short of the LP series. These things are mini-suns, 9K lumens per or so, and that’s part of why I’m getting rid of them. They just throw way more light downrange than I actually need (even with the driving/combo pattern).
Now, in preparation for installing them I did one thing you might want to change back – I depinned the dimmer circuit on the pod pigtails. If you want the dimmer control, you could reterminate with a 3-pin plug again (and I'm including enough extra connectors to do that). As of now, it would wire up to be max light or off with no middle setting.
Comes with the light pods, brackets, rock guards, and several different 3-pin wiring harnesses you can use to make up your own cables. $600 shipped takes it all.
iStan814
