https://phoenix.craigslist.org/nph/pts/d/2006-sprinter-van-palfinger/6661121622.html
IN PHOENIX: Palfinger lift gate. Direct bolt on without modification to 2006 Sprinter (Spare tire must go inside). Can probably be mounted on any truck or box van with simple modification of mounting plates. This lift was removed from my sprinter van today, August 3rd. This lift is has the automatic tilt function while raising and lowering, so it stays flat as it swings through its travel arc. It has the 2 optional foot buttons of the lift to raise and lower, hands free, using your feet.
Includes:
Dash module: Dual LED Indicator, on / off switch
Power wires, approx 18 feet (enough for a 144" sprinter van), and dash panel wiring, also 18'
3 exterior panel switches and complete wiring
1 remote control with coiled wires ($250 option)
2 integrated foot switches for up and down with load ($400 option)
2 mounting plates to direct bolt on to a 2006 Sprinter Van
All bolts and fittings to mount to your van exactly as it was to mine
Same as this:
https://www.palfinger.com/en/products/tail-lifts/models/mbb-c-500-van_p_3661
https://www.palfinger.com/en-us/products/liftgates/models/the-minifix_p_2951
New retail is probably around $5,000 USD
Lift worked fine when I bought the van months ago. Due to bad #2 cylinder in the diesel engine, the van has not moved since and the battery is now dead. I pulled the liftgate off today, Aug 3rd, and clearly marked the 5 wires that I had to disconnect to remove the panel mount switches on the van body. Only connection needed to reinstall is reconnect these 5 small control wires with butt connections. 5 minutes of work for electrical, probably 2 hours for whole project. Took me 1 hour to remove by myself.
If ad is up, the liftgate is still for sale. Call between 10 AM and midnight. Lift is at my house and can be loaded into a standard pickup with 3 or so people. I can deliver for a small fee.
Price reduced to $750 OBO, Cash only, no scammers, no money orders, no paypal, no payments, nothing out of state... full cash up front.
Thanks,
Peter in Phoenix
281-772-121-one text or call 10 AM to Midnight Pacific time.
Includes:
Same as this:
Thanks,
Peter in Phoenix
