Pelican 1600 Boxes - Price drop $80.00 each- Pasadena area
mard
Hello everyone. Cleaning the garage and getting rid of some Pelican 1600 boxes. Middle foam was cut on these so depending on your needs, you might need to get the middle foam. These currently go from $160 to around $175 new. These would be great for your sensitive expedition equipment or as gun storage. Due to my hectic schedule, I prefer local transactions unless you can provide shipping labels. I currently do not have time to get shipping estimates. UPS and FEDEX online is showing shipping rates of $30-$40 with insurance and tracking. I am not sure how accurate that estimate is. Please see a more detail description below from Pelican.
Price drop: $80.00 each, that half off retail!
6 left
http://www.pelican-case.com/1600.html
Description
This 1600 BLACK CASE comes with Pelican’s unique Pick ‘N Pluck foam. This foam is pre-cut which allows you to customize the interior by half inch cubes. Trace out the item you want in the case and simply pluck the foam out by hand, no tool required. You can customize your case in less than 15 minutes.
Unbreakable, watertight, airtight, dustproof, chemical resistant and corrosion proof. These are some of the features of this Pelican Protector Case that offers total; protection for your equipment. It is made of Ultra High Impact structural copolymer that makes it extremely strong and durable. Its exclusive 1/4" (6.4 mm) neoprene o-ring and ABS latches seal perfectly and includes an automatic purge valve for quick equalization after changes in atmospheric pressure. Your equipment can fit into the high density foam or padded dividers for total subjection and protection against impact, vibration or shock. A nameplate (included) can be personalized (engraved at additional cost).
This case is NATO codified and tested to MIL C-4150J (Military Standard), IP-67 (Ingress Protection) and ATA (Air Transportation Association). Unconditionally Guaranteed ... forever.
Specs
Interior (l/w/d)
21.43" x 16.5" x 7.87"
Exterior (l/w/d)
24.25" x 19.43" x 8.68"
Dimensions
Buoyancy Max
74.96 lbs
Range Temp
-10 / 210 °F
Lid / Case Depth
1.75" / 6.12"
Weight
14.11 lbs (with foam)
13 lbs (w/o foam)
Foam Set
1611 1612 Pick 'N' Pluck™
Opt. Accessories
1600IP Instapak Quick® RT
Certificates
IP67 MIL C-4150J Def Stan 81-41/STANAG 4280 ATA 300
mard
Gonna pass on the jerry cans as I have two on the m416 trailer already. I am looking for mud terrain or all terrain take offs for the trailer, size 235/85/16 if you have that, plus cash on my side depending on condition of course. Thanks
Sophia Lopez
