pickup and four wheel camper
roamingaz
Relisting my truck, had it sold localy but the guy couldn't get enough cash and I also had a trade offer in New York but it also fell through.
The only reason I am selling this rig is to get back in a landcruiser or maybe a jeep, if I can't sell it then I will continue with my original plans for it and build a pre runner-expo-madmax truck
Truck and camper $7000 cash may trade for a fj40 or fj55, 4runner or ? I open for ideas. Email me directly at roamingaz@yahoo.com with details of your trade offers. I can add some cash to my trade if you have something that is really cool.
Camper is for sale seperate for the expo only price of $2400 or trade me something.
Jesse 480-304-2906 early morning (after 4am) is the best time to reach me. Truck and camper are located 32 miles east of Phoenix
Known issues
~Hot start problem, slow to start after driving long distance, needs to cool for 10 minutes then starts fine, maybe insulate the starter or use a gear reduction starter? no problems around town driving.
~No door keys, hasn't been a priority I guess
~Rear fuel pump needs replaced, cost $55 through bronco graveyard
~Pass. side vent wing window broken from the locksmith that tried to unlock my door, I was planning on replaceing all the door glass, locks, and weather stripping just haven't got that far yet
Interior is ok but carpet could use a scrub, some wear on drivers seat but no rips, back seat is a fold down bench that if you are a short person can be use as a bed.
1991 Ford lariat extended cab
all work done in the last 4 months
new fuel injected 302 professionaly built by Airpark Auto Projects in North Scottsdale, has about 300 miles and full warrenty for 2 years. The shop owner Tim did my rebuild and most of his buisness comes from sellers with their cars going to the big auctions like Barret-Jackson, top quality work and a great guy to do buisness with.
Fuel mpg is 12-16, but the speedometer is off so maybe better, and I need to drive it more with my gps to track actual miles driven
Rebuilt Transmission, around 4000 miles but no paperwork, had it checked while the engine was being replaced
all hoses replaced, vacuum lines, engine mounts, new starter, selanoid, water pump, battery, cables, timing cover. Engine was bored .30 and kept stock.
radiator flushed and filled with premium coolant
new wheel bearings
superwinch hubs,
tie rod and rod ends
gear box
sway bar, sway bar drop bracket
4" lift, pro comp springs in front, Bilstien 5100 shocks.
6" lift springs/blocks rear older rancho shocks
Procomp braided extra long brake lines front/rear
New calipers, pads
New american motoring mojave rims
Toyo MT 285-16 400 miles on them
Custom swing out tire carrier built by Get Bent Fab Works in Mesa, tubing is chrome-moly and hub was custom machined by 4 wheelers in Phoenix.
CAMPER
1984 Four Wheel Camper Aluminum framed, lightweight 640 pounds.
2 Optima yellow top batteries
125 watt solar panel, trace charge controller
recently refurbished propane furnace
Norcold TEK 2 12 volt/110 volt fridge
full size propane tank
2 burner stove
sink
6 gallon water tank
ARB awning
2 crank up jacks with new cable and assemblies, work very well
NEW rear door with screen door
NEW front popup supports custom built by four wheel camper
New water fill door an dplumbing
NEW 12 volt lights inside and out
sleeps 4
scissor steps included
Pop up material no rot or repairs but does have cosmetic discoloration on part of it on the over head bed. Does not leak at all anywhere
The cab over section has been completely rebuilt useing marine grade plywood, this camper does not leak anywhere!
I have the original owners manual and paperwork from 1983!
dhuss
