Bikersmurf
Just got back from a shorter trip, and before ja few days before that we drove 1700 miles (round trip) through the Rockies. I was checking over the truck for a 1300 mile trip through the Rockies again, and I found that the pinion seal (rear axle) is weeping a bit. On its own I wouldn't be too concerned, but there is noticeable play side to side and up down. It also feels like it is ramping up a bit.
It has about 260k miles on it.
Should I pull the third member before the trip?
I think, at a minimum, I should unbolt the driveshaft and make sure the pinion nut hasn't loosened off and investigate further. I haven't pulled a Dana 70 apart before and don't know if it uses a crush sleeve or shims or just what.
Any thoughts or suggestions about what I'll find? How urgent is a rebuild?
Thanks in advance.
@ujoint @Abitibi @iggi
Thanks in advance.
