propane addiction
It is quite tough. My buddy recently took his 2005 GMC pickup (don't remember the model but IIRC his model had the largest gas engine available for them at the time) with me on easy trails and within a mile his steering pump's pulley shaft broke!Seems like all the stock montero stuff is tough as nails! If you did that to a shock from a gm it would fail in a few weeks!
It's actually a 'good' problem because most other 'upgraded' 4x4's aren't capable of running those speeds and we usually end up suffering at the slow pace set buy those other rigs when we wheel with groups.It sounds like the coils must ride nice if your making some 60mph desert passes! I will push mine well over 100mph in the sand! I am also into the crawling so I am going to custom build a doubled set of 241c t cases to slow it up some!
I have. This forum is great for those who want to moderately upgrade their rigs with aftermarket parts and there are a lot of knowledgeable folks here who can advise with those types of upgrades but it isn't heavy on the hard core modding. It's why I suggested you check out 4x4wire's mitsu forums. There you'll find folks discussing various power plants, drive trains, dual xcases, etc.I'm surprised no one has commented on the sbc powered montero!
