sonoronos
Usually broken down on the side of the road
I currently use a Plano Green Dry-Storage ammo box as a step stool. It has supported my weight (about 185) lbs well while working on the truck, provides about 10" of rise, is compact at 15"x8"x10" and lightweight at about 3 lbs. I like it because I can keep a few things in it, store it in my truck, and pull it out with the handle whenever I need a lift.
The other advantage of the ammo box is that it is very nearly vertical. This allows me to place the step stool right next to the tire/wheel, allowing me to get very close to the vehicle.
I'm wondering what other folks are using as step stools for their rigs - more specifically: step stools that they store in their rigs. I need a bit more lift, and I was wondering if there was a better alternative than simply buying a taller ammo box.
I think something like the well known Kikkerland folding step would be great, but something more robust and less prone to folding up. I have tried both my kikkerlands and with the gyrations of engine work on a lifted vehicle, they are not quite robust enough.
The only other requirement is that it has to be plastic / polymer.
