Hi everyone! In my current camper re-build (a 2004 Palomino Bronco 1500 pop-top), I'm stuck at the very beginning -- establishing a balanced foundation. Basically, I can't seem to get the camper to sit square in the bed of my truck, the frame of the camper warps and leans to the right. This is to such an extreme that the deadlock on the door no longer engages (see the attached photo).
Any thoughts?
Currently, I've been using wooden pallets (about 4 inches thick) to raise the camper off the bed (because otherwise the camper hits the walls of the truck's box and the cabover). I've tried a few orientations of the pallets, and even switched out to a new set of high-end and identically-sized pallets (thanks to my friend who drives a freighter), and I still can't get the camper to sit square. When I jack the camper up, the camper goes square (and I can tell by the seam of the door fitting perfectly), but as soon as I lower the camper back down onto the bed of my truck, it warps to one side.
I read Jefe's article (and referencing this thread) about using a hard foam liner, so that's my next plan -- picking up some 1inch foam to place either on top of, or below, the pallets (or maybe I should opt for entirely foam as Jefe does?). A little part of me wonders though why it's not sitting right in the first place?
It's loaded into a 2009 F150, and the Bronco sticks out the backend so I've also got the tailgate down and the camper is resting on the tailgate (which I wonder if that might have something to do with it?).
Does anyone have any thoughts on what might help? Or have you experienced a similar circumstance? Thank you all, and take care!
Any thoughts?
