portable propane fueled freezer/fridge
HINO SG
after a somewhat-extensive search of the Camping Equipment forum, I didn't find any current information on 3-way power portable fridges (propane/electric).
Suggestions?
Both Norcold and Dometic make three way (12V/120V/propane) reefer/frezer products. The 3-way products do NOT chill or freeze on 12V, they simply maintain a 'pre-chilled' reefer to keep it cool. In 12V mode they generally require about 18 Amps per hour draw. They also require a <1 Amp feed to operate in propane mode - this supplies the computer with power.
I have a Dometic 120V/propane reefer/freezer in my Airstream 'hunting lodge' and it works fairly well on propane or 120V (Honda genset). I plan on getting a 3-way and have done some research, which is ongoing.
These are made primarily for RV applications where you do not want to be running propane while driving - generally considered bad ju-ju.
I was assuming that.
Still not finding actual portable Norcold or Dometic 3-way available at the company websites.
I Work with someone that has about a 7 cubic foot electric/propane fridge. I believe its for sale. If you are interested I can get some pics, find out if its in working order and get you a price if it is for sale.
possibly. Is the unit intended for stationary, mobile(RV), or portable use?
I'd probably be interested, regardless.
pm on the way.
Its for RV use. Its currently in a truck that used to pull an enclosed race car trailer. This guy used to drive locally.
kerry said:
Not as long as it is running on gas and not electricity.
Did they have gas powered appliances in the 1700's??
I just find it funny. I guess what's the point of JUST not using electricity. If you are going to go old school, go all the way.
FYI: If you are looking at propane carefully research whether or not the model you choose can work at angles. Many (if not most) will shut off as soon as you start tilting offroad.
Pete
2eleven
