RaderGuy
Years in the making to piece together these two, and what a sweet combination it is.
The truck is a 1998 Dodge Ram 2500, 1 Owner. Oregon purchased and owned 5 speed 12 Valve. Quad Cab Short bed. Making it a 1/2 year only available configuration with the 12 valve engine, short bed + quad cab. Only 82,000 original miles on it. It is all original, rust and body damage free. The interior is like new. Everything works as it should. There are no modifications to the truck. The Killer dowel pin KDP Has been tabbed, with receipt of this work included. All other paperwork, original keys, original window sticker, maintenance records since new. Truck has been garaged and covered since new. Key fob entry with a 1998 Clifford alarm system - very robust. Includes original tailgate as well in good shape.
The Truck + Camper are for sale as a package. Package Price $61,689.
The Camper is for sale separately as well. Camper Price: $21,000.
The truck will only be for sale individually if/when the camper sells individually.
Specs:
1998 Dodge Ram 2500
82,000 original miles.
12 Valve 5.9 Liter 6BT Cummins Turbo Diesel engine, last half year these were put into the Rams, with the desirable P Pump.
5 Speed Manual NV4500 Transmission, recently serviced with fresh proper Redline MT-85 OEM Spec Gear Oil Brass Synchro Safe.
Quad Cab - 2 Front doors + 2 Suicide Doors. 98 Was the first year for this
Short Bed 6.5Ft Bed. 1998 Was the first year for the short beds. Also meaning shorter wheelbase for better off-road maneuvering
Fresh Line-X In the Bed, Installed at Line-X Clackamas.
Factory Steel 16 Inch Wheels with factory chrome trim rings and center caps - more reliable than the common alloy wheels that are known to corrode and cause leaks.
Crack Free Dash protected under new Carhartt Dash Cover
New Set of Cooper Discoverer S/T Maxx 255 85 R16 Tires
Factory Two-Tone Paint, Bright White + Silver Metallic
AC + Heat work perfectly
Power Locks, Power Windows, Cruise Control.
2 Key Fobs, 3 keys.
Factory AM/FM / Tape / CD Head Unit with equalizer. Works well
Seats 6
Husky Floor Liners, front and rear
Original OEM Carpet Floor Mats in Great shape, always covered
Recent service includes:
Rear Brake cylinder replacement, full brake fluid bleed / refill
Manual transmission drain and fill with proper OEM spec fluid
All service records from Day 1, owners paperwork, manuals, and brochure.
Specs:
1998 Dodge Ram 2500
2 Key Fobs, 3 keys.
Seats 6
